zx_drift Posted October 31, 2009 Share Posted October 31, 2009 Hey I have a 280zx turbo (just swapped in) and the car idles nicely with 20" vacuum, but as soon as I push the gas, the car dies. Drops to 0" vacuum and just stalls. If I let off quick, it starts idling again, but if I hold down the throttle it dies completely. Any ideas? I really can't figure this out. Quote Link to comment Share on other sites More sharing options...
kolonelklink87 Posted November 1, 2009 Share Posted November 1, 2009 What engine management are you using? Quote Link to comment Share on other sites More sharing options...
zx_drift Posted November 1, 2009 Author Share Posted November 1, 2009 turbo ecu and harness Quote Link to comment Share on other sites More sharing options...
kolonelklink87 Posted November 1, 2009 Share Posted November 1, 2009 suspect AFM(?)... if you have access to another one try to replace for troubleshoot... check all the cabling (i hear sometimes people can put the connector on backwards) and test the unit as per FSM. Failing that try troubleshooting your problem with "the efi bible". Quote Link to comment Share on other sites More sharing options...
zx_drift Posted November 2, 2009 Author Share Posted November 2, 2009 The MAF tested good (followed steps in FSM). I bypassed the air regulator, and it did manage to get off idle, but misses throughout the range (sounds like a Subaru). Any other ideas? Also, where is this EFI bible? Thanks. Quote Link to comment Share on other sites More sharing options...
BleachZee Posted November 4, 2009 Share Posted November 4, 2009 If its not the AFM, then you probably have one or several air leaks. Are you able to get it to idle at or below 1000 rpm? since you are using the turbo ECU and harness, you did also put in a 280ZX turbo AFM, right? (and distributor) Quote Link to comment Share on other sites More sharing options...
zx_drift Posted November 6, 2009 Author Share Posted November 6, 2009 Yes, 81 distributor with CAS at the pulley, turbo AFM. It does idle, about 800 rpm or so. Hooked up at timing light and it is 20 BTDC, but if I open the throttle it retards (instead of advancing) down to 0 then the ignition cuts out pretty much. Quote Link to comment Share on other sites More sharing options...
