flywheel questions
The "turbo/2+2/240mm" flywheel has a little more clamping force so the release fingers are a little beefier and stand up a little taller. The problem comes if you leave the longer sleeve on the transmission when you swap in a taller clutch assembly. The longer sleeve pushes on the release when you mate the trans back on the engine and so the clutch is in permanent disengage. You can shorten the slave rod to add some clearance but it's just so much easier to make all the parts match while it's all apart...
70-71 S30 has an adjustable slave rod
