injector issues
norsemanz
Ok gang heres my problem – Maybe someone can pointout the obvious that I’m missing here. Took My 75 L28 motor off the scca track and decided to make some mods since I was not restricted by a class rules. My L28 motor was basically stock and since I had a worn out 83 L28 turbo motor sitting here I decided to turn my 75L28 into a very mild turbo car. Here are the changes made to the 75 L28 I bolted on the turbo exhaust manifold and added a T3T4 Hybrid Turbo along with a good size Intercooler. I also bolted on a 240 sx 60mm throttle body and during that swap reinstalled the stock L28 TPS on that TB . I then Installed the Turbo injectors from the 83 turbo motor and the AFM from the 83 Turbo (after swapping guts from 75AFM) motor. End of Changes .Went to fire it up today and I have no fuel being sprayed by the injectors. I have spark to the cylinders and everything else appears fine but no gas being injected. With ignition on I have an electric signal to all injectors but no spray happening. Plugs are bone dry.Noid light shows no pulse. Checked and cleaned all connections on ECU,Dropping Resisstors, Fusible links.Power going into ECU and coming off pin 15 I'm relly at a loss here Any Ideas. Need Help Thanks
Very carefully describe what fuel components you changed and how you routed them, please. Do you have pressurized fuel in the rail? Are you sure your lines are not reversed? Did you change computers? Hot side on the injectors doesn't mean you have the ECU providing a signal.
