240zwannabe Posted November 15, 2009 Share Posted November 15, 2009 alright so, i went to the track this past friday and ran about 6 passes. on the way home i noticed my oil pressure was down to 30 psi. i stopped off and got a quart of oil and added a little, it then went up to 35 psi and cruising speeds. my oil pressure at cruising speeds in usually 41 psi. the next day i changed the oil and filter to see if that would fix it. now, it's only running 35 psi still. i looked up fluid capacities for sr's and found 3.25 quarts of oil on wikipedia. could this be the issue? is this capacity wrong? Quote Link to comment Share on other sites More sharing options...
240zwannabe Posted November 15, 2009 Author Share Posted November 15, 2009 ok, i just looked up oil capacities from a number of other sites to confirm and they're saying its 3.5 quarts not 3.25... Quote Link to comment Share on other sites More sharing options...
hoov100 Posted November 15, 2009 Share Posted November 15, 2009 what RPM? I think the standard was 10psi for every 1k RPM's. Quote Link to comment Share on other sites More sharing options...
240zwannabe Posted November 15, 2009 Author Share Posted November 15, 2009 what RPM? I think the standard was 10psi for every 1k RPM's. i usually cruise about 2000-2500 rpm Quote Link to comment Share on other sites More sharing options...
hoov100 Posted November 16, 2009 Share Posted November 16, 2009 you might have to shim the spring in the oil pump. (can't remember its official name) Did you replace the pump before you installed the motor? Quote Link to comment Share on other sites More sharing options...
240zwannabe Posted November 16, 2009 Author Share Posted November 16, 2009 you might have to shim the spring in the oil pump. (can't remember its official name) Did you replace the pump before you installed the motor? i didn't build the car a friend of mine did and i bought it just beofre i moved to texas. the point is that this all started happening after the drag strip. i'm afraid i may have messed something up. Quote Link to comment Share on other sites More sharing options...
240zwannabe Posted November 16, 2009 Author Share Posted November 16, 2009 i think i may have found the problem, just as i thought...not enough oil. so i must have burned some at the track. the sr20 holds 3.5 quarts but alot of people are saying they use 4 quarts even. thought i'd add that for future searches Quote Link to comment Share on other sites More sharing options...
