Guest garhpd Posted November 15, 2009 Share Posted November 15, 2009 Hey guys, I recently inherited a 1976 280z that is in sweet condition. It has been sitting covered for a number of years. I see an RB swap in it's future, however for now I am trying to get it running with the original engine so I can drive it around for a bit. Anyhow, I cleaned out the fuel tank and replaced the fuel pump. If you jumper the pump the car will run. Without the jumper, the fuel pump only has power when you are cranking the engine. If the engine starts and the key goes back to the ON position, the pump quits and then the engine dies shortly after. I replaced the main relay with a new one. I also tested the fuel pump switch circuit in the afm and I have continuity when you open the air valve. Is there anything else I should check? Thank you! Quote Link to comment Share on other sites More sharing options...
Guest Gr8White Posted November 17, 2009 Share Posted November 17, 2009 garhpd said: Hey guys, I recently inherited a 1976 280z that is in sweet condition. It has been sitting covered for a number of years. I see an RB swap in it's future, however for now I am trying to get it running with the original engine so I can drive it around for a bit. Anyhow, I cleaned out the fuel tank and replaced the fuel pump. If you jumper the pump the car will run. Without the jumper, the fuel pump only has power when you are cranking the engine. If the engine starts and the key goes back to the ON position, the pump quits and then the engine dies shortly after. I replaced the main relay with a new one. I also tested the fuel pump switch circuit in the afm and I have continuity when you open the air valve. Is there anything else I should check? Thank you! Try the ignition switch, mine did the exact same thing. Mine would start missing in traffic too and I could turn the key off and then on again and it would run just fine for a few miles more then repeat the process.... Quote Link to comment Share on other sites More sharing options...
NewZed Posted November 17, 2009 Share Posted November 17, 2009 (edited) Deleted. Edited November 17, 2009 by NewZed Didn't read first post completley. Quote Link to comment Share on other sites More sharing options...
