mr jdm Posted November 19, 2009 Share Posted November 19, 2009 Hey whats up, I have a sr20det mounted in my bay using mckinney crossmember. I have to make my own crossmember, I cant use theres. Making one isnt a problem. I dont know how high or low the trans should sit. I currently have this short shifter. http://farm3.static.flickr.com/2654/3702290862_cefc494b4b.jpg Now, with the shifter in and trans where I think it should be, the green piece is about 1/4-1/2" below the top of the tunnel. Is this right or should I mount my trans lower? Quote Link to comment Share on other sites More sharing options...
MONGO510 Posted November 19, 2009 Share Posted November 19, 2009 The trans main shaft needs to be as close to paralell as possible to the differential pinion. If you are off more than a degree or so you will have vibrations. The correct angles will determin where you trany should be mounted. Search will be your friend! Hope this helps Mongo Quote Link to comment Share on other sites More sharing options...
280zjoel Posted November 19, 2009 Share Posted November 19, 2009 when I made my trans mount, i took and input shaft and a peice of tubing to a friend of mine who is a machinist and had him press the two together and balance it out, then i Inserted it into my trans and lined it up to the center of my diff yoke, then made the mount according to that. It worked out pretty good. Quote Link to comment Share on other sites More sharing options...
fast-datsun Posted December 2, 2009 Share Posted December 2, 2009 call me with what ever problems your having, so we can correct them... Quote Link to comment Share on other sites More sharing options...
