Miles Posted October 22, 2002 Share Posted October 22, 2002 What works best to clean a fuel tank? I am sure my 30 year old 240Z tank has some rust etc. Thanks Miles Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted October 22, 2002 Share Posted October 22, 2002 I once had a tank boliled out from a 54 Chevy. The professional shop must have baked the tank instead of boiled it since a good crust of crud coated the rust.I ran a waak solution of muriatic acid for about 20 minutes in the tank before my nerve ran out. I placed about 10 feet of heavy link chain and shook it off and on for a couple of weeks rinsing it out with water and air dried it with compessor air. Finally the water ran clear. I called around and bought this "red gas tank sealer" in a quart can that you poured in the tank and moved around until it was coated all over. You definitely had to be careful with all the openings not getting plugged with the sealer.Worked good. If you have one boiled out make sure they have the understanding that you want the inside clean too. I took the tank for a second cleaning but the effort was futile and then took matters in my own hands with shake ,rattle and roll of the chain. Quote Link to comment Share on other sites More sharing options...
Guest AlsoRanFPrepared Posted October 22, 2002 Share Posted October 22, 2002 I took my tank to a local fuel tank/radiator repair place. They boiled it out, fixed the leaks, pressure tested it, reapplied new foam pads and tagged it as being tested and by whom for $60. It was well worth it. -Mark Quote Link to comment Share on other sites More sharing options...
SpeedRacer Posted October 22, 2002 Share Posted October 22, 2002 You might want to see if you have a Gas Tank Renu http://www.gastankrenu.com/welcome.htm dealer near you. I had them do this to my tank and it came out great. PVC plastic coated inside and out plus it's covered by a lifetime warranty. Quote Link to comment Share on other sites More sharing options...
TomoHawk Posted October 23, 2002 Share Posted October 23, 2002 RThe radiator guy in my area told me to fill the tank and run it all down, the fuel filter should catch the rust. Quote Link to comment Share on other sites More sharing options...
