TomoHawk Posted October 24, 2002 Share Posted October 24, 2002 The old stock one is cracked and looks real bad, so I took it off and push the button down with my thumb to shift. I want something nice and classy. Maybe a shifter handle from another car will fit? Any ideas? I would prefer a new shifter with an H-shaped gate on it... Quote Link to comment Share on other sites More sharing options...
Mike C Posted October 24, 2002 Share Posted October 24, 2002 Hurst Dual gate is the one you are thinking of. I have a B&M Quicksilver ratchet shifter for sale. Shifter, both round and a T handle, console from a Star shifter, and the cable. You will need trans bracket an shift arm. I'm asking $50. Email me I'll send you a pic. If you want to go junkyard and have a 3 speed, the 73-81 Camaro shifter is pretty decent, cheap too. It is a "slapstick" shifter. Push it sideways and forwards and it only goes up one gear. Pretty cool. Also found in Vegas and Monzas. (I am assuming you have a V8 car? Othewise, a newer Z shifter might work.) Quote Link to comment Share on other sites More sharing options...
TomoHawk Posted October 25, 2002 Author Share Posted October 25, 2002 My car is totally original stock everything. The Hurst shifter has both sets of PRND21 on both sides. I was asking if there is a shifter that works like a 4-speed, only for an automatic trans. Quote Link to comment Share on other sites More sharing options...
TomoHawk Posted October 25, 2002 Author Share Posted October 25, 2002 I took apart the shifter handle and I found out that all there is in there is a pushrod & spring. So all you need is a shifter handle that's big enough to bore a hole (about .75inch diameter and .6 inch deep) to fit over the shifter and then a hole through to the top. Make a longer pushrod & put it together for a cool 4-speed looking auto-trans shifter. That way you can use a carbon one or whatever. Mine will be aluminium and the 'button' will be have a slot-shape. Another idea would be to replace the whole shifter handle by removing the current one from the fork-like thing at the bottom, then weld on another shifter shaft of the kind that turns you on. Even more like a 4-speed look brcause you're actually using a 4-speed shifter lever! Just figure out how to run the pushrod inside. Quote Link to comment Share on other sites More sharing options...
