shadesh Posted November 25, 2009 Share Posted November 25, 2009 Is this the correct way to install the Diff Mount Insulator? I am confused as to how the bolt, nut, and the washers are supposed to go?? Does the bolt slide down the diff with the nut at the bottom? Should there be a washer that goes between the diff and the insulator? Can someone take a quick peak and let me know. Please. Thanx! Quote Link to comment Share on other sites More sharing options...
draft.phunk.amd Posted April 9, 2010 Share Posted April 9, 2010 I'm currently also trying to install my diff mount, and would appreciate this information. And if anyone knows the measurements/specifications (width, height, pitch of threading, part name or number if applicable) of the insulator-installation-nut which goes onto the differential-case-mounting-front-insulator, through the differential-case-mounting-front-member. I don't have that nut, and am having a hard time finding it. Without it, the nose of the differential slams onto the damper-plate each time I add or remove power to the drive-shaft. Quote Link to comment Share on other sites More sharing options...
NewZed Posted April 10, 2010 Share Posted April 10, 2010 (edited) I'm currently also trying to install my diff mount, and would appreciate this information. And if anyone knows the measurements/specifications (width, height, pitch of threading, part name or number if applicable) of the insulator-installation-nut which goes onto the differential-case-mounting-front-insulator, through the differential-case-mounting-front-member. I don't have that nut, and am having a hard time finding it. Without it, the nose of the differential slams onto the damper-plate each time I add or remove power to the drive-shaft. Shadesh's pictures are right. The bolts go in from the bottom. Here's an FSM picture. The transmission mount nut is the same. Take it to Ace Hardware or a similar store and ask them to match it. All you need is thread pitch and diameter, the outer dimensions can be different. Edited April 10, 2010 by NewZed Quote Link to comment Share on other sites More sharing options...
