deMideon Posted November 21, 2002 Share Posted November 21, 2002 I was just looking at Pete's relay hookup and I was wondering if anyone has hooked it up so that both the high beam and low beam come on at the same time when you select high beam. It seems to me that it would be that much brighter, and would only take the addition of one diode. Does anyone think it is worth doing that way? Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted November 21, 2002 Share Posted November 21, 2002 Wow, that's a good idea, I never thought of that. The only concern I can think of is maybe the bulb would not last as long from the extra heat generated... Quote Link to comment Share on other sites More sharing options...
deMideon Posted November 26, 2002 Author Share Posted November 26, 2002 Bump.. no one tried this? Quote Link to comment Share on other sites More sharing options...
spotfitz Posted November 26, 2002 Share Posted November 26, 2002 When I first did the headlight relays I had mine hooked up this way, only because I didn't have enough relays and thats how I had to drive around for acouple of days, even during the day do to switch problems. I had to adjust them down some, but it was alot brighter. I had considered leaving the brights that way after installing the other relay, but thought it may over heat the headlight housing or shorten the bulbs life, as previously stated. Quote Link to comment Share on other sites More sharing options...
