Lost oil pressure!!!!!
Could you have uncovered the pickup in loading it on your trailer? Any sharp impact/bump that might have started your pickup falling off...was the pickup welded...connections on your oil psi shutoff switch fine and the rest of those wires good?
Hopefully and quite likely just something simple...good luck.
Yes Ross,the pickup is welded on and dont see why loading on trailer would have caused a problem wires to safety switch are ok this switch requires 15# oil pressure to operate fuel pump good thing it happened at idle and not 6ooo rpm going down the track!!!!!!
Could also be that vibration caused the pump mounting bolt/stud to loosen. Electric gauge? If so, wires may have fallen off. If you used a lot of moly lube and it's a new motor, that can plug filter. Change filter for sure.
Went to the track last week,made 2 passes,everything fine. no noises,leaks are anything. loaded car back on trailer fuel pump shut down... have fuel pump safety switch. looked at guage and No oil pressure!!Heres the rudown on my engine.... 4oo s/b 72 model block 4 bolt mains,ported and polished stock heads, Performer RPM package,cam,lifters valve springs,750 manual choke carb,Intake,hardened pushrods,Crane Enigizer roller rockers,guide plates,Summit high volume oil pump, electric fuel pump 5-7 # block was totaly done at head shop, new mains,cam bearings,rings,valve seals etc. crank reground and polished,5angle valve job etc. double roller timing chain set, new harmonic balancer. Hooker full length headers. car ran fine, strong just cant imagine what caused the oil pressure problem. any ideas would be appreciated icon_confused.gif
