Fauxre Posted December 19, 2009 Share Posted December 19, 2009 I've been searching threads, but can't find an answer. Has anyone here done the JTR V8 swap on a 260Z? I've removed the engine compartment wiring per the manual, as far as I can tell. When I backtracked the unused wires into the passenger compartment to remove them, I found one was connected to the transistor ignition module. Is this correct? Quote Link to comment Share on other sites More sharing options...
hoov100 Posted December 19, 2009 Share Posted December 19, 2009 I've been searching threads, but can't find an answer. Has anyone here done the JTR V8 swap on a 260Z? I've removed the engine compartment wiring per the manual, as far as I can tell. When I backtracked the unused wires into the passenger compartment to remove them, I found one was connected to the transistor ignition module. Is this correct? Your asking how to wire in a small block chevy with an HEI? Quote Link to comment Share on other sites More sharing options...
Fauxre Posted December 19, 2009 Author Share Posted December 19, 2009 (edited) Yes. I have accounted for all the engine related wires and I want to remove the belt interlock system as well. The manual is vague as to some of the specific wire colors that need to be removed. Edited December 19, 2009 by Fauxre clarification Quote Link to comment Share on other sites More sharing options...
jay260z Posted December 19, 2009 Share Posted December 19, 2009 what wires do you need to find, ie ing hot, starter sol., constant hot? Quote Link to comment Share on other sites More sharing options...
Fauxre Posted December 20, 2009 Author Share Posted December 20, 2009 Specifically, does the Green-Red wire from the transistor ignition box connect to anything in the engine compartment with the V8 swap? Quote Link to comment Share on other sites More sharing options...
jay260z Posted December 21, 2009 Share Posted December 21, 2009 no it dose not. Quote Link to comment Share on other sites More sharing options...
Fauxre Posted December 22, 2009 Author Share Posted December 22, 2009 Thanks for the help.:burnout: Quote Link to comment Share on other sites More sharing options...
jay260z Posted December 22, 2009 Share Posted December 22, 2009 not a problem Quote Link to comment Share on other sites More sharing options...
