IdahoKidd Posted December 25, 2009 Share Posted December 25, 2009 While swapping the l28et from an 83 zx into my 77 280, can I install the cruise control as well or does that get too complicated? It would be nice to have the cruise.... Thanks, Leonard Quote Link to comment Share on other sites More sharing options...
Nigel Posted December 25, 2009 Share Posted December 25, 2009 Don't bother with trying to retrofit the ZX system. Just get the Audiovox CCS-100 cruise control kit. It's a universal kit that comes with pretty much everything you need for the installation. It's especially simple to install if you have a manual transmission. It'll just run off of the tach signal. I've installed these kits in three cars, the first being my 240Z 6 years ago, and it's worked flawlessly ever since. http://www.amazon.com/Audiovox-CCS100-Universal-Vacuum-Control/dp/B00029WQTW Nigel '73 240ZT Quote Link to comment Share on other sites More sharing options...
Guest Rolling Parts Posted December 25, 2009 Share Posted December 25, 2009 What he said, don't bother with the old electronics and vacuum system. If I remember correctly the ZX speed sensor is embedded in the ZX speedometer cluster. Quote Link to comment Share on other sites More sharing options...
Sketch_hs Posted December 27, 2009 Share Posted December 27, 2009 Does that kit use the brake switch as a shut off too? Quote Link to comment Share on other sites More sharing options...
Nigel Posted December 28, 2009 Share Posted December 28, 2009 Does that kit use the brake switch as a shut off too? Yes, and if you have a manual transmission, it senses a sudden rise in RPM to know when the clutch has been push in. Nigel '73 240ZT Quote Link to comment Share on other sites More sharing options...
IdahoKidd Posted December 28, 2009 Author Share Posted December 28, 2009 Good enough! Thanks guys. Quote Link to comment Share on other sites More sharing options...
