MyLaDyZ Posted January 2, 2010 Share Posted January 2, 2010 Hi im about to drop a L28e into my 240 But i decide to pull the intake main and exhaust main off, for header and a new gasket. When i looked into the intake mainfold it was bad REAL BAD 30 years worth of carbon build up straight up GUNK i tried carb cleaner, purple power with a little brush to get in there to scrub it out but nothing is working. What should i use to clean it out? Quote Link to comment Share on other sites More sharing options...
S130Z Posted January 2, 2010 Share Posted January 2, 2010 Take it to your local machine shop and have them hot tank it. Last thing I got hot tanked about that size cost me about $20, it's worth the price. Quote Link to comment Share on other sites More sharing options...
MyLaDyZ Posted January 2, 2010 Author Share Posted January 2, 2010 sounds good thanks Ever tried pressure washer? Quote Link to comment Share on other sites More sharing options...
Ineptitude01 Posted January 4, 2010 Share Posted January 4, 2010 Pressure washers will take the paint right off of most surfaces (ask me how I know). If that's not going to be a big deal, you can try, but it's going to be time consuming and just plain not as good. Hot tanking is great, but if it's just not happening, I recommend the following: + The choice of champions. Happy cleaning! Quote Link to comment Share on other sites More sharing options...
theguppies Posted January 4, 2010 Share Posted January 4, 2010 there's a shop in san jose that can hot tank heads for $20. Quote Link to comment Share on other sites More sharing options...
Ineptitude01 Posted January 4, 2010 Share Posted January 4, 2010 That's good to know! I've been using Lynn Automachine in Redwood City, and they've never done me wrong. Quote Link to comment Share on other sites More sharing options...
MyLaDyZ Posted January 4, 2010 Author Share Posted January 4, 2010 Pressure washers will take the paint right off of most surfaces (ask me how I know). If that's not going to be a big deal, you can try, but it's going to be time consuming and just plain not as good. Hot tanking is great, but if it's just not happening, I recommend the following: + The choice of champions. Happy cleaning! Some good electric tooth brushes? have you really done this or you just messing with me Quote Link to comment Share on other sites More sharing options...
Ineptitude01 Posted January 4, 2010 Share Posted January 4, 2010 Haha, oops! I didn't notice they were electric! My bad. I've never used an electric one. I just use the cheap Rite Aid ones. But now that I mention it... Maybe something to try? Quote Link to comment Share on other sites More sharing options...
70 Cam Guy Posted January 5, 2010 Share Posted January 5, 2010 Haha, oops! I didn't notice they were electric! My bad. I've never used an electric one. I just use the cheap Rite Aid ones. But now that I mention it... Maybe something to try? I wonder what a Sonicare would do or how one of the other ultrasonic tooth brushes would do. Quote Link to comment Share on other sites More sharing options...
blue72 Posted January 5, 2010 Share Posted January 5, 2010 Small steel brush and some good cleaner. I'm not sure how intense this carbon buildup is, but a little steel bristled brush with a long handle can probably go a long way toward getting that gunk out of there. I really doubt a nylon bristled toothbrush is going to help much on this particular material. Quote Link to comment Share on other sites More sharing options...
Ineptitude01 Posted January 6, 2010 Share Posted January 6, 2010 Hey, I cleaned my whole head with a toothbrush! I mean, it TAKES a while, but if you're being real cheap about things... Quote Link to comment Share on other sites More sharing options...
MyLaDyZ Posted January 6, 2010 Author Share Posted January 6, 2010 Hey, I cleaned my whole head with a toothbrush! I mean, it TAKES a while, but if you're being real cheap about things... Ill let you guys know how long it will take me, i wish i had a carmera to show you guys how bad it is Quote Link to comment Share on other sites More sharing options...
blue72 Posted January 7, 2010 Share Posted January 7, 2010 Okay, I admit that you can clean up dirt and most good with a stiff bristled nylon brush. I cleaned the entire outside of a head with only a rounded flat bladed screwdriver, some engine degreaser and a nylon brush. If you're really on a budged it's amazing how creative you can get:) That stiff carbon buildup is a different beast though. I've removed carbon buildup from inside a combustion chamber by hand and even a steel bristled brush has a difficult time getting rid of that stuff. Quote Link to comment Share on other sites More sharing options...
Ineptitude01 Posted January 7, 2010 Share Posted January 7, 2010 Oh, the other trick that sometimes works is getting under it with a razor blade. if it's stiff enough, you can peel it off in chunks. My head wasn't gunked too bad, so I didn't have a whole lot of trouble getting it perfectly clean. Quote Link to comment Share on other sites More sharing options...
