dagold Posted January 9, 2010 Share Posted January 9, 2010 I have been searching and can't find a clear post. Can someone please tell me what ECU should go with a late 77 cali car with MT? Thanks Dave Quote Link to comment Share on other sites More sharing options...
ModernS30 Posted January 9, 2010 Share Posted January 9, 2010 i have been searching and can't find a clear post. Can someone please tell me what ecu should go with a late 77 cali car with mt? Thanks dave a 77 mt ecu? Quote Link to comment Share on other sites More sharing options...
dagold Posted January 9, 2010 Author Share Posted January 9, 2010 Manual Tranny I am not sure witch of the following A11-600-000 or a A11-601-000 Quote Link to comment Share on other sites More sharing options...
IdahoKidd Posted January 9, 2010 Share Posted January 9, 2010 601 if it has the altitude switch. Yours does. But you already know all of this. Quote Link to comment Share on other sites More sharing options...
dagold Posted January 9, 2010 Author Share Posted January 9, 2010 Thanks Idaho, the 77 came with a spare ECU (600) and believe that is why I am messed up. I currently have 3 ECUs (2 600s anfd a 601) and got them mixed up. Sence I knew one of the 600 was from the 77 I assumed the other should be a 600. However last night I hooked the spare intake up to my wiring harness (so I could see what injectors are doing) come to find out 1,2,and 3 are now hanging wide open with what I thought was the orignal ECU and 600#2 they are not opening at all. Hooked the 601up this morning and got all six firing correctly. Now I just need to replace the oil as it now has a grab load of Gas in it then put everything back together. Quote Link to comment Share on other sites More sharing options...
dagold Posted January 11, 2010 Author Share Posted January 11, 2010 Want to say thanks for the help as she started this afternoon. Don't have all the gremlins all worked out yet (running a little rough). Need to set timing, adjust airflow and check vacuum pressure and all the other fun stuff that will get it running correctly. Quote Link to comment Share on other sites More sharing options...
