Jared Posted January 11, 2010 Share Posted January 11, 2010 For those using it, did you connect it to the upper or lower cable? If to the lower cable, did you mount it in the trans tunnel or route the lower cable into the car and mount it under a seat? It seems a clunky kind of way to do this, but I can't come up with another way to run the stock 83 speedo with a transmission that has no built in sensor. thanks, Jared Quote Link to comment Share on other sites More sharing options...
m1noel Posted January 11, 2010 Share Posted January 11, 2010 For those using it, did you connect it to the upper or lower cable? If to the lower cable, did you mount it in the trans tunnel or route the lower cable into the car and mount it under a seat? It seems a clunky kind of way to do this, but I can't come up with another way to run the stock 83 speedo with a transmission that has no built in sensor. thanks, Jared Jared, My 78 only have one cable (no cruise conrol-bummer). But you don't really hook it up to a speedo cable anyway. It wires up to a speed sensor on the tranny and then drives the stock mechanical speedo. What trans are you working with that has no sensor? Oh, and I placed my box inside the right side kick panel where the old FI computer used to reside. Mike Quote Link to comment Share on other sites More sharing options...
Jared Posted January 11, 2010 Author Share Posted January 11, 2010 My 83 has an upper and lower cable. I guess attaching it to the lower speedo cable will the the way to go then. The trans is a 6sp Z33. Quote Link to comment Share on other sites More sharing options...
