Two80z4me Posted January 13, 2010 Share Posted January 13, 2010 So, I put in the E12-80 and I wired it in using the existing wiring harness to the new E12. I traded it out because my 280z dizzy had alot of shaft play in all directions, and I had an E12 that was clean and had no shaft play. I installed it, put the 280z rotor/cap onto it and used the existing green/red wire from the 280z harness into it as well. My question is, what does the green wire do?(hopefully goes to the tach?) and the red im guessing is power? I know there is a different way to do it, using this wire set up from the coil . http://datsunzgarage.com/engine/e1280x.jpg which leads to my next Question, does anyone have any photos of this set up? I tried sending a wire from my coil on the positive side to the positive on the dizzy, and same with the ground. All I got was just it trying to start, but there was nothing, it would turn and everything, but wouldn't start. The car was running previous to pulling the distributor and installing this one. I need to know which wire is the tach sensor, and which is the 12v+ like in the photo so I can get this thing running again Quote Link to comment Share on other sites More sharing options...
cpt_morgan Posted February 14, 2010 Share Posted February 14, 2010 Have a look at this pal. I stumbled across this when I was asking myself the same. Cheers Quote Link to comment Share on other sites More sharing options...
Guest Flauski Posted February 22, 2010 Share Posted February 22, 2010 have a look at what? Quote Link to comment Share on other sites More sharing options...
cpt_morgan Posted March 7, 2010 Share Posted March 7, 2010 Sorry the link didn't post for some reason... who knows Anyway; http://atlanticz.ca/zclub/techtips/distributor/index.html The green wire is the trigger signal I believe Quote Link to comment Share on other sites More sharing options...
