turboHLS30 Posted January 23, 2010 Share Posted January 23, 2010 Hello all I have a 75 280z and I converted it to carb and was wondering what the stuff inside the yellow box is.(see pic) Also can I remove it or is it a necessity to have??? Quote Link to comment Share on other sites More sharing options...
Two80z4me Posted January 23, 2010 Share Posted January 23, 2010 Fusible Links? Nice intake manif! Quote Link to comment Share on other sites More sharing options...
turboHLS30 Posted January 23, 2010 Author Share Posted January 23, 2010 Thanks. So can I remove it?? Quote Link to comment Share on other sites More sharing options...
ModernS30 Posted January 23, 2010 Share Posted January 23, 2010 Really? First there are fusible links, under that is a external voltage regulator for you alternator. you need both, you can replace the fusible links with MAXI-Fuse (ideal) and then you can replace your alternator with a 240sx one or a 280zx or zxt (I used the ZXT 70 amp internal regulator) If you do a bit of searching you will learn alot. Quote Link to comment Share on other sites More sharing options...
turboHLS30 Posted January 23, 2010 Author Share Posted January 23, 2010 So what is it called?? I can't do a search if I don't know what it's called. Quote Link to comment Share on other sites More sharing options...
Two80z4me Posted January 23, 2010 Share Posted January 23, 2010 Thanks. So can I remove it?? no, you can't. let me get the thread how to upgrade them though, those fusible links control alot of important wiring, on my 280z I have two of those boxes that control Alternator Ignition fuel injection/ignition/spark headlight relay. on your 75 it is different. it controls your Ignition alternator/ignition http://www.atlanticz.ca/zclub/techtips/fusiblelinks/index.html there is a link to an easy upgrade that will save you ALOT ALOT ALOT of stress with your Z. Quote Link to comment Share on other sites More sharing options...
turboHLS30 Posted January 23, 2010 Author Share Posted January 23, 2010 Thanks man. I'm gonna look a little deeper into that in a little bit. Quote Link to comment Share on other sites More sharing options...
Two80z4me Posted January 23, 2010 Share Posted January 23, 2010 Thanks man. I'm gonna look a little deeper into that in a little bit. yeah its really easy to do actually, I give you a summed up version. There will be 4 wires for your blocks (color White W/Red) you will see one of the Red/white's going to your starter, you will peel back the wiring harness and follow that to the fuse block, then remove it. Go to Walmart buy a schosche fuse block and get 50A fuses. Take a 4 or 6 Gauge wire and have it go to the top of the new fuse block, and then have it attach to the +Pos battery terminal on the starter. then take the other two wires and attach them to the other side of the new fuse block, then your clean sailing without having to stress over these ancient wiring blocks. Quote Link to comment Share on other sites More sharing options...
turboHLS30 Posted January 23, 2010 Author Share Posted January 23, 2010 Cool thanks Quote Link to comment Share on other sites More sharing options...
turboHLS30 Posted January 23, 2010 Author Share Posted January 23, 2010 On the other hand that motor is for sale. The complete swap. Not trying to make this a FS thread or anything just putting it out there. If anybody else has a way they eliminated those things please post it up. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Two80z4me Posted January 23, 2010 Share Posted January 23, 2010 On the other hand that motor is for sale. The complete swap. Not trying to make this a FS thread or anything just putting it out there. If anybody else has a way they eliminated those things please post it up. Thanks in advance. there is no way to completely eliminate them, just different variations of the same thing I told you. Complete motor specs? Quote Link to comment Share on other sites More sharing options...
turboHLS30 Posted January 23, 2010 Author Share Posted January 23, 2010 L24 E88 head, 40 DCOE mikuni's with manifold. The turbo kit is a cartech kit and has a Rayjay T04B turbo 3 inch downpipe, 5 speed tranny, ACCEL coil pack w/ accel spark plugs. Comes with intercooler and piping. Quote Link to comment Share on other sites More sharing options...
Two80z4me Posted January 23, 2010 Share Posted January 23, 2010 L24 E88 head, 40 DCOE mikuni's with manifold. The turbo kit is a cartech kit and has a Rayjay T04B turbo 3 inch downpipe, 5 speed tranny, ACCEL coil pack w/ accel spark plugs. Comes with intercooler and piping. Is it running? and How much? Quote Link to comment Share on other sites More sharing options...
turboHLS30 Posted January 23, 2010 Author Share Posted January 23, 2010 Yup it's running and I want atleast $2200 for the whole swap Quote Link to comment Share on other sites More sharing options...
Two80z4me Posted January 23, 2010 Share Posted January 23, 2010 Yup it's running and I want atleast $2200 for the whole swap oof-da, willing to part lol? Quote Link to comment Share on other sites More sharing options...
turboHLS30 Posted January 24, 2010 Author Share Posted January 24, 2010 Yeah Quote Link to comment Share on other sites More sharing options...
Two80z4me Posted January 24, 2010 Share Posted January 24, 2010 Yeah how much for the intercooler and piping and the turbo/exhaust manif Downpipe Quote Link to comment Share on other sites More sharing options...
turboHLS30 Posted January 24, 2010 Author Share Posted January 24, 2010 I'm not sure thats basically the whole turbo kit Quote Link to comment Share on other sites More sharing options...
Two80z4me Posted January 24, 2010 Share Posted January 24, 2010 I'm not sure thats basically the whole turbo kit exactly Quote Link to comment Share on other sites More sharing options...
ModernS30 Posted January 24, 2010 Share Posted January 24, 2010 exactly Not even close. Your missing a turbo ECU and wiring, turbo dizzy, boost control. Oil pan, oil lines, catch can afm/maf and alot of other stuff I am sure I am missing. Remember Two80z4me you have a efi car, this is a blow thru setup. Quote Link to comment Share on other sites More sharing options...
