Bolt in a/c condenser 240z 280z
zgeezer
The 280Z a/c condenser is "ambidextrous". You can rotate it 180 degrees and it fits in both locations. The benefit for a Series I S30 is that the radiator support has holes punched in that will allow you to run your a/c compressor lines to either side and still maintain the correct lines to the top and bottom of the condenser. You can mount the a/c compressor on the right or the left side and then rotate the condenser. This is important because the a/c compressor pressure line must enter at the top or the bottom of the condenser [i don't recall which is which]. You are covered either way. It is clean and neat.
