Having some questions about installing new fuel pump for SR20DET
icapture
Bought this fuel pump on eBay a few months ago and have recently got some time to work on the Z. I am attempting to install this fuel pump but there are 4 hoses on the Z, and only one inlet/outlet on the fuel pump. I forgot to take pictures of how the stock fuel pump was set up, and I left some of the stock fuel tubing at Napa (had to buy some new fuel line since I had to cut the old ones off) so I cant really try and just reassemble the stock set up and start over again.
Can someone help me out with this? Which lines go where on this new pump?
Area in question, which hose to I attach to the new pump?
New fuel pump attached to old fuel pump bracket:
Old fuel pump:
And what is this? Fuel filter?
That is not a fuel filter. It is a fuel damper. It's there to prevent pressure surges. With a good adjustable fuel pressure regulator and pump you wont need it.
One of the lines from the gas tank to the pump is your fuel feed line.
One of the lines from the engine to the gas tank is your fuel return line.
The other two should be vent/vapor lines which go to your liquid/vapor seperator near your gas filler neck.
