It wont run with gas, please help.....
Guest ttoude
It will start and drive but ONLY with 1 second of gas from the pump, (just a quick flick of the gas switch).
But if I leave the fuel pump switch on constant I get black smoke and quickly shuts off.
1977 280 with 81 turbo motor and 83 ECU and harness and turbo fuel pump. (no dropping resistor like the 81's)
Stock injectors
NEW fuel pressure regulator
stock fuel pump 95psi etched into the side
all wiring is per the Hybridz turbo swap
The question: please help, the motor went in on Dec 28 and is still not behaving. I'm almost ready to just set the whole thing on fire and buy a horse. Horses dont have any wires to confuse :(
The "Is it possibles":
Is it possible that the injector harness' are mixed up?
Is it possible that my hijacked fuel switch is to blame?
I'm lost and angry
Also I found the order for the injectors at the ECU end, 101,102 etc. But the injector end of them doesnt seem to be marked. Is there a way to identify the inj harness order without de-tapping all the wires and following them?
afm tested bad put a new one on and it ran well for a bit. now Im gonna check the CHTS loop.
BTW what is a CHTS loop? I dont see it in the faq acronym page
