Guest Anonymous Posted January 29, 2001 Share Posted January 29, 2001 The windshield weatherstripping MSA sells for $50 - is this Nissan part, or copy? If copy, is it of sufficient quality? And if a copy, how much is the nissan gasket? My windshield seems to dribble jsut a bit of water when it rains for 3 days straight and I wanna fix it and keep my rust-free car that way. Also, when replacing the weatherstripping(I plan on POR-15ing the metal underneath the gasket) would it be advantageous to put a bit of silicon between the gasket and body and between the gasket and windshield? Or just put it in dry? Also, my windshield has a light streak from a dirty/bad/broken wiper. Are $100 windhsields you get from any glass dealer good enough quality to use? I bet nissan glass is ridiculously expensive, no? ------------------ Morgan http://z31.com/~morgan/s30 http://carfiche.com Quote Link to comment Share on other sites More sharing options...
Guest KraZ4spd Posted February 7, 2001 Share Posted February 7, 2001 Victoria British has Windshields for around $100 they're tinted on top but they seem to be OK Quote Link to comment Share on other sites More sharing options...
Guest Fast Frog Posted February 7, 2001 Share Posted February 7, 2001 Morgan: MSA windshield Gasket/weatherstripping are of good quality. I've had several windshields and rear deck glass replaced with this MSA product. Generally, the installers (I don't do it myself-I'd break something)use good quality silicon sealer to mate the gasket to the glass and to the metal areas that make contact with the gasket. I don't remember if these gaskets are Nissan oem or aftermarket. Rick [This message has been edited by Fast Frog (edited February 07, 2001).] Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted February 7, 2001 Share Posted February 7, 2001 I watched the guys put in the last windshield that I had installed. They used an epoxy type sealant that is very adhesive and very permanent. They put a little in each side of the rubber and then wiped it away where it was mashed out after installation. I was not terribly pleased with the installation but I attribute that to the poor judgement, on my part, of purchasing Precision Replacement rubber. I now have Nissan rubber waiting to be installed. Craig Quote Link to comment Share on other sites More sharing options...
Al Keller Posted February 8, 2001 Share Posted February 8, 2001 Problems with Precision weatherstripping???? Quote Link to comment Share on other sites More sharing options...
SpeedRacer Posted February 8, 2001 Share Posted February 8, 2001 Check around because my local Guardian glass shop come out to my house and installed a brand new tinted windshield for $108.46 (yes I said installed for $108.46!). I did, however, supply a new rubber gasket. They used a butyel (sp) sealer on it. I used the complete Precision kit on the whole car and it worked very well except for the doors. The Precision door weather is not metric and a little to hard so you end up slamming the doors all the time. I switch to the factory door seals and everything was OK. Many people have reported the proble with the door seals to Precision but they have never fixed it. Quote Link to comment Share on other sites More sharing options...
