Thagard Sump Fitting Help
datsun dave
I remember reading a post, from the people who made the Thaggard pan, saying that the engine would need to be installed first, then the pan. You should be able to find the thread. However, if you can bolt the pan on the engine first and then fit the engine in, as pat1 said, that would make things easier.
Thanks.
Put the pan on the engine then drop it all in, its a huge PITA to pull the pan off from under the car.
I have a Thaggard pan.
Out of curiousity do you have more pics of your pan/pickup?
Thanks will put up some more sump pictures tomorrow at work its 7.30pm here in the UK.
A few more pictures of the sump top plate & oil pick up pipe, sorry i have no pictures of the trap doors fitted.
Now that looks like a proper finished Thagard pan. :2thumbs: If I'd have used my brain, I could have done my Thagard pan that way, hence saving $$ on buying current pan...
Good job Dave!
Good job Dave!
Ditto!
If it wasn't a pain to pull the pan I would try to gut mine and redo it like this one... oh and have to pull the oil pump off to convert to internal pickup again... argh!
  • 3 months later...
