Delasangre4231 Posted March 23, 2010 Share Posted March 23, 2010 (edited) Had this problem start up a few days ago. Basically when that car is running or not if I put the key in acc or on I get an audible "click" coming from behind the dash on the far left end and when the click occurs everything electrical that's running at the time flickers or drops in power and then resumes withing a second. The engine is not being effected by the flickering. The flickering includes everything inside and out, headlights, dash, radio, engine accessories such as the vacuum pump... Help? Edit: Also my windows have stopped working completely however everything else seems to be fine besides the flicker... It solved itself for a few minutes where the windows worked but then started up again. Edited March 23, 2010 by Delasangre4231 Quote Link to comment Share on other sites More sharing options...
roger.svoboda Posted March 23, 2010 Share Posted March 23, 2010 (edited) windows not working is probably in the switches on the door. The contact strips get worn and don't make contact. Hard to explain without taking it apart. I should have taken pics when I did it. the other stuff. Go thru the basics. Battery good and load tested good. Fully charged. Battery cables clean, tight and free of corrosion on both ends (lots of people ignore this but hey no battery no workee). Check fusible links clean, tight and freee of corrosion. If you have all that proven good you can start on more exotic solutions. Edited March 23, 2010 by roger.svoboda Quote Link to comment Share on other sites More sharing options...
