Two80z4me Posted March 25, 2010 Share Posted March 25, 2010 Hey, I have a 78 280z and I had a question about removing the Air conditioning Lines. Just as a caution my 78 is a vacuum operated heating system, so if removing the bronze A/c Lines from the engine bay will make me lose vacuum and lose my heating and defrost, then it wont work. I wanted to know if even if I didnt have compressor will it still possibly have a/c coolant in the lines? and Can I remove the bronze lines without it cancelling out my vacuum for defrost and heat? Quote Link to comment Share on other sites More sharing options...
X64v Posted March 25, 2010 Share Posted March 25, 2010 If there's no compressor (i.e. hoses just bare-ended where the compressor would be), there's definitely no freon in the A/C system. Vacuum-operated systems are run by engine manifold vacuum; removing the (normally pressurized) A/C lines will not affect your heat/defrost operation. In short, have at it. Quote Link to comment Share on other sites More sharing options...
Two80z4me Posted March 25, 2010 Author Share Posted March 25, 2010 thats exactly the answer I was looking for, thanks. The only reason I asked is because I removed and bled the freon in my saab 900 turbo and then went to remove the lines and freon was gushing out like mad and that stuff is terrible smelling. Quote Link to comment Share on other sites More sharing options...
