TritleZ Posted April 4, 2010 Share Posted April 4, 2010 (edited) I bought a 1976 280Z over the winter and have been having troubles getting it to run smoothly. I need help identifying these components and where the connections (vacuum?) go to. I'm not finding them in the FSM (assuming I'm overlooking something) (1) The long skinny hose going across the intake manifold/valve cover, and connects to the yellow canister on the pass. side (what is it?, it just looks out of place) (2) The top of this is cracked, or a nipple has broke off? (3) The wire with the bullet connector goes to the bottom of the throttle body (4) This solonoid of some sort? Has two ports that are missing hoses, where do these go? Edited April 4, 2010 by TritleZ Quote Link to comment Share on other sites More sharing options...
MONGO510 Posted April 4, 2010 Share Posted April 4, 2010 1. The canister is a vacuum reservoir for the heater/AC controls 2. There was a nipple/vent on your Dashpot. May work fine without it. 3. The bullet connector goes to your BCDD(Boost Control Deceleration Device), it is disconnected, may be bad. 4. Can't remember. Mongo Quote Link to comment Share on other sites More sharing options...
TritleZ Posted April 4, 2010 Author Share Posted April 4, 2010 Would any of these cause the issues I'm having in this video? Quote Link to comment Share on other sites More sharing options...
MONGO510 Posted April 4, 2010 Share Posted April 4, 2010 Probably not! how long does it run? Does it restart? How long before it will run again? What do you do to make it restart? Sounds like it is going very lean. Check electrical connections. Sounds like something has high resistance, is getting hot, and losing its connection. Check main harness connections under dash, fuel pump connections. Mongo Quote Link to comment Share on other sites More sharing options...
Daeron Posted April 4, 2010 Share Posted April 4, 2010 pictures are WAY too big, takes too long to load Quote Link to comment Share on other sites More sharing options...
