Tyler Posted April 22, 2010 Share Posted April 22, 2010 Something odd is happening with the idle. So when I start it up, I have to play with the gas for about 3 minutes until the temperature probe moves on the dash, then if I let go of the gas it'll stumble low to about 400 rpm and die. On the other hand, if I pop the hood and manually give the throttle a little "blip" it'll go to about 850 rpm and idle great. So I thought maybe I have to just give it a tap or two of the gas pedal to recreate the same thing. NO! It doesn't work. If I then proceed to pop the hood and "blip" it again it'll idle fine. Also after some time driving trying to figure this out, the idle still draws to a stall and will have a hard time regulating the idle unless I manually press the throttle lever on the carbs. -Idle at 850 rpm. It drops to about 650-700 rpm with lights, fan, and radio on. -Idle screw down 3/32 of a turn past touching -Mixture screws set to 1 1/4 turn out all the way across For reference the carbs are: 45 DCOE 36mm choke 155 Main Jets 170 Corrector Jets 55 F8 Idle Jets F16 Emulsion tubes On my previous tune last where I microtuned with the ColorTune Tool for the mixture I got for the turns out #1- 1 1/4 #2- 1/1/4 #3- 3/4 #4- 1/1/4 #5- 3/4 #6- 3/4 Please HELP! Thanks Tyler Quote Link to comment Share on other sites More sharing options...
josh817 Posted April 22, 2010 Share Posted April 22, 2010 Why not just raise the idle up? Turn the idle screw in more. For my setup I have all the carbs balanced onto one screw so I don't throw them out of balance when I raise the idle. I turn one idle screw, and they all adjust the same amount across the board. Quote Link to comment Share on other sites More sharing options...
Tyler Posted April 22, 2010 Author Share Posted April 22, 2010 On 4/22/2010 at 6:03 AM, josh817 said: Why not just raise the idle up? Turn the idle screw in more. For my setup I have all the carbs balanced onto one screw so I don't throw them out of balance when I raise the idle. I turn one idle screw, and they all adjust the same amount across the board. I have raised the idle up, but it won't hold until after I manually hit the throttle on the linkage arms. I've had it set to about idling anywhere from 500-1100 rpm but still the same issue. How do you have it setup to adjust the idle with one screw? Any pictures? That would be awesome if I could. Thanks Quote Link to comment Share on other sites More sharing options...
randy 77zt Posted June 17, 2010 Share Posted June 17, 2010 if you get a piece of 5/32 vacuem line and put 1 end in your ear and 1 in the carb throat by the throttle blade you can sync the carbs by the sound of the air rushing past the throttle blades.the louder the air the more the better the mix is.try to get all barrels sounding the same.a good healthy hissing sound is good Quote Link to comment Share on other sites More sharing options...
LowCarbZ Posted June 17, 2010 Share Posted June 17, 2010 I'm thinking the problem lies in your linkage setup or choke cable. Have someone sit in the car and hit the gas while you watch the linkage. See if it moves the same as if you do it by hand. Quote Link to comment Share on other sites More sharing options...
