Booster, Upgrade? Replace?
  On 4/23/2010 at 4:46 PM, FubarI33t said:
What brake boosters will bolt into the S130. Are there any more powerful boosters?
I say just have a spacer machined to eliminate the booster. Power brakes? Who needs em. If we don't need power steering we don't need power brakes. More pedal feel anyway.
  On 4/23/2010 at 5:30 PM, FubarI33t said:
I have so much slop in my pedal. and have to pump it twice to get it to work decent. All 4 corners have been bleed twice. new pads. remand calipers, and rotors. SS lines. DOT3 fluid. still like a F350 with ranger breaks
If you're having to pump it to get brake line pressure you still need to bleed it. A bad booster would just require more pedal pressure to maintain the same brake line pressure.
How about a master cylinder? New, bleed the master? Bleed the brakes again, if you have to take the calipers and rotors off and hold them up while bleeding and having another person pump and hold. Get as much air out as possible. If your pedal is soft bleed and bleed and bleed more.
