evil_datto Posted May 23, 2010 Share Posted May 23, 2010 Are you telling me that every single L20A N/A I have seen has the WRONG injectors on it? Are you telling me that JECS just for shits & giggles decided to use the SAME part numbers for DIFFERENT injectors that look exactly the same? These GREEN injectors are EXACTLY the same. I've seen many L20A's, I'm always going to the wrecking yards to grab stuff. And in all my time I have never seen anything but GREEN injectors on the L20A N/A S130's. What can I say? I'm seeing only green injectors on S130 Fairlady Z's & Fairlady 280Z's, I just don't see how every single one (I've seen a lot) have tossed out these original non-green injectors you're talking about for the green ones. I'll edit my posts if you want to show me where in this Nissan documentation it says that the original Japanese RHD S130 2.0 Fairlady Z has something other than the green injectors. If by some chance they are actually still green, and carry the same exact JECS part number (like you said, yet you said they are a different colour anyway), then really it's a fairly honest mistake that someone would think they were the same exact thing. Quote Link to comment Share on other sites More sharing options...
Tony D Posted May 24, 2010 Share Posted May 24, 2010 Bosch did that all the time... I don't have time to dig out my stuff, believe what you want. You didn't answer my actual parts substitution question, you just insisted you were right. Like I said, believe what you want. Quote Link to comment Share on other sites More sharing options...
bigjohnsonzc Posted May 26, 2010 Author Share Posted May 26, 2010 so i could possible use the injectors that E.D. has but Tony D ur affraid theyre going to run Lean in an open loop, due to the ECM, correct? so how can i tell besides just putting them in to see if they might work or not.. im sure you all know that removing the fuel injection system is a big pain.. so it is odviously perferd to have the right ones or the ones that will work.. lol E.D. youve ran these injectors in your L20E correct? it would probably help if i pulled the part numbers off my old injectors too huh? sorry guys my mistake.. going trew a divorce and trying to go back and forth threw two houses is a pain.. atleast i still got my car! lol HA! thanks for the help guys.. keep the info comming Quote Link to comment Share on other sites More sharing options...
bigjohnsonzc Posted June 7, 2010 Author Share Posted June 7, 2010 OK guys .. got some numbers off the injectors.. on the electrical plugg there is a number "522" and right below that on the injector there a few numbers.. they are. "0-280-150-105" can u guys tell me anything on that? Quote Link to comment Share on other sites More sharing options...
Tony D Posted June 8, 2010 Share Posted June 8, 2010 http://www.ratwell.com/technical/Injectors.html You will find it there... Quote Link to comment Share on other sites More sharing options...
bigjohnsonzc Posted June 21, 2010 Author Share Posted June 21, 2010 On 6/8/2010 at 10:11 PM, Tony D said: http://www.ratwell.com/technical/Injectors.html You will find it there... So TONY D, Do you think it would make a difference if i used the normal 280 injectors.. The CC or Unit size seems to be simmalar its just the way the ECM will see the new injectors that im concerned about.. figure some of you guys would have already experienced this and or already have done a change like this and would know if there would be a dramatic change in the way she runs. Quote Link to comment Share on other sites More sharing options...
Tony D Posted June 22, 2010 Share Posted June 22, 2010 ECU doesn't see injectors, they are an output device. The only thing it 'sees' is RPM, AFM, CLT, TPS, etc... You can put 370CC injectors on there and the ECU won't know the difference, it will just run pig rich as it has no method for pulsewidth alteration. It doesn't know 370 from 280 from 160 from 550 from 720CC injectors. It fires the same pulsewidth based on the input signals from the above input devices. There isn't even an O2 sensing loop to know that you're rich and to taper off the pulsewidth. It is a dumb ECU. Quote Link to comment Share on other sites More sharing options...
bigjohnsonzc Posted July 2, 2010 Author Share Posted July 2, 2010 so than the 280z injecters i have will work just fine!? Quote Link to comment Share on other sites More sharing options...
Tony D Posted July 3, 2010 Share Posted July 3, 2010 R.I.F. Quote Link to comment Share on other sites More sharing options...
bigjohnsonzc Posted July 6, 2010 Author Share Posted July 6, 2010 On 7/3/2010 at 7:31 AM, Tony D said: R.I.F. WHAT? haha sorry Tony, dont know what that stands for.. Quote Link to comment Share on other sites More sharing options...
jasper Posted July 6, 2010 Share Posted July 6, 2010 On 7/6/2010 at 10:32 PM, bigjohnsonzc said: WHAT? haha sorry Tony, dont know what that stands for.. http://www.rif.org/ Quote Link to comment Share on other sites More sharing options...
bigjohnsonzc Posted July 8, 2010 Author Share Posted July 8, 2010 wow.. ok.. well a simple yes or no would work.. but cool thanks! Quote Link to comment Share on other sites More sharing options...
kolonelklink87 Posted July 14, 2010 Share Posted July 14, 2010 (edited) On 7/8/2010 at 11:31 PM, bigjohnsonzc said: wow.. ok.. well a simple yes or no would work.. but cool thanks! no... if they are a different part/size of course the answer is no. you cant swap in a turbo onto a NA ecu just like you cant put big injectors on an ecu that doesnt have the ability to modulate its output signals based on exaust gases etc. Tony was saying you COULD just pput them on an run pig rich... it will "run", but you might need to clean the spark plugs every 10km by hand and you power will be stuffed et-cetera. dont just throw anything that fits on, use the right part. *double facepalm* -pete p.s. & FYI I have a JDM L20e and the injectors are a cream colour. Edited July 14, 2010 by kolonelklink87 Quote Link to comment Share on other sites More sharing options...
