S30TRBO Posted April 26, 2010 Share Posted April 26, 2010 On one end of this harness in the car is a green wire and a black with white stripe wire that was in a plastic t-connector plug. The green is the +12 on the pump and the black and white (now I think I figured it out) goes to the ignition. The question is those that are using the stock wiring and SDS EM4-6F with a relay; are you using the green wire on the stock harness to go to #87 on the relay? Also on the SDS fuel pump relay diagram there are (2) +12v key sources do I use the black/white wire to one of those two or snip it? Quote Link to comment Share on other sites More sharing options...
S30TRBO Posted May 3, 2010 Author Share Posted May 3, 2010 For future reference for anyone in my case. I emailed SDS to confirm and they said they like to see all devices wired through the key so you are sure they are off when the key is off. Quote Link to comment Share on other sites More sharing options...
