p90 head /n47 block
kvansic162
  • 3 weeks later...
P90 cam centerline is same height as other heads although valve stem lengths may be different due to the "higher roof". Not sure about valve lengths, just thought I remember something of that nature. Shims for the cam towers are for when you mill the head to maintain that centerline height. You should use flattops of zeroish deckheight to keep compression 8.5ish with a 1mm headgasket. The 2mm headgasket will get you even lower. Round dish under a peanut shaped closed chamber is not ideal and will yield unnecessarily low compression ratios of 7.4 with a 1mm headgasket or less for the 2.I don't understand why the factory did the p90/dished combo except to make triple dog sure there was no detonation.
