mchong75 Posted May 4, 2010 Share Posted May 4, 2010 Hey guys, is there another name for Auxiliary air valve? (1976 280z) I called up few of the local parts store and they "looked" at me funny as if Auxiliary air valve doesn't exist...just because it's not in their system. Quote Link to comment Share on other sites More sharing options...
Heathhh Posted May 4, 2010 Share Posted May 4, 2010 On 5/4/2010 at 2:00 PM, mchong75 said: Hey guys, is there another name for Auxiliary air valve? (1976 280z) I called up few of the local parts store and they "looked" at me funny as if Auxiliary air valve doesn't exist...just because it's not in their system. It is actually called the Auxiliary Air Regulator. At least for my 82' 280zx. I'm sure the name for it has stayed the same throughout each model year though. I'm surprised that the guys at the store couldn't figure it out what you were saying...how sad. Quote Link to comment Share on other sites More sharing options...
Administrators BRAAP Posted May 4, 2010 Administrators Share Posted May 4, 2010 It should be covered in your shop manual, (Haynes manual which every member has or should have). If you are referring to the cold running idle compensator circled in the picture below, the common term for it on '75-'78 cars is; "Air Regulator". Hope that helps, Paul Quote Link to comment Share on other sites More sharing options...
mchong75 Posted May 4, 2010 Author Share Posted May 4, 2010 On 5/4/2010 at 2:39 PM, BRAAP said: It should be covered in your shop manual, (Haynes manual which every member has or should have). If you are referring to the cold running idle compensator circled in the picture below, the common term for it on '75-'78 cars is; "Air Regulator". Hope that helps, Paul I finally found out MSA and Zcarsource also calls it "Air Regulator". However, Autozone, O'Reilly, NAPA, and couple of other stores locally have no IDEA what I'm talking about...... Quote Link to comment Share on other sites More sharing options...
Pharaohabq Posted May 5, 2010 Share Posted May 5, 2010 hehe it was probably made before most of the guys at autozone were born. Quote Link to comment Share on other sites More sharing options...
