SteveZ Posted May 15, 2010 Share Posted May 15, 2010 Well my stocker took a dump on me today, looking for a good replacement. I dont want to mess with regulators just looking for a direct replacement for mine. Motor is a stock L26 with SUs. Any input on a replacement and tips for the install? Thanks. Quote Link to comment Share on other sites More sharing options...
xxxpatsabxxx Posted June 17, 2010 Share Posted June 17, 2010 (edited) yea mine took a dump this week too. im thinking about one of these two to replace the rear original fuel pump, most likely the 4-7 because i have a decent fuel pressure regulator and its within the suggested range for my weber dgv carbs. its a little pricey for something simple but im sure it will do the job shouldnt be too hard of an install either. hope we are talking about the same fuel pump.... http://www.autozone.com/autozone/catalog/accessories/accProductDetails.jsp?itemIdentifier=732036_0_0_&skuDescription=Mr.Gasket+/+2to3.5PSI42GPHelectricfuelpumpforimportcarburetors&brandName=Mr.Gasket&displayName=2to3.5PSI42GPHelectricfuelpumpforimportcarburetors&skuDisplayName=Mr.Gasket&categoryNValue=10099999&navValue=100501&categoryDisplayName=2to3.5PSI42GPHelectricfuelpumpforimportcarburetors&parentId=00-10&itemId=501-10&store=5561&productId=732036 http://www.autozone.com/autozone/catalog/accessories/accProductDetails.jsp?counter=6&categoryDisplayName=Performance&fromString=search&itemIdentifier=732035_0_0_&productId=732035&sortType=&parentId=8-10&filterByKeyWord=fuel+pump&categoryNValue=100008&navValue=100501&fromWhere=&itemId=501-10&displayName=4+to+7+PSI+35+GPH+electric+fuel+pump+for+domestic+carburetors&store=5561&skuDisplayName=4+to+7+PSI+35+GPH+electric+fuel+pump+for+domestic+carburetors&brandName=Mr.+Gasket Edited June 17, 2010 by xxxpatsabxxx Quote Link to comment Share on other sites More sharing options...
Zmanco Posted June 17, 2010 Share Posted June 17, 2010 The Mr. Gasket pump is spec'd for 4-7 psi which is high for SUs, although I know a guy locally who is running it with no problems. Years ago I replaced mine with this: Airtex 110-E8016S It was trouble free with SUs, and also triple webers. I'm still using it to feed a surge tank for my turbo engine so it clearly has plenty of flow. Quote Link to comment Share on other sites More sharing options...
SHRALP_GNAR Posted June 21, 2010 Share Posted June 21, 2010 (edited) I would strongly discourage you from going with a Mr. gasket. I've burnt up two of 'em in 6 months. The dude at the auto parts store said that more than half of the Mr. gasket pumps he sold came back. It Could have been because I had them mounted in the engine bay instead of right out of the tank. If you already have one I would suggest mounting it in the back. Edited June 21, 2010 by SHRALP_GNAR Quote Link to comment Share on other sites More sharing options...
