Adding 220vac to shop
vashonz
I have a detached 30x40 shop, and want to run 220vac out there.
This is what I have right now:
200A main panel in house
Shop has its own 60A (double pole) breaker that runs to a feeder panel in the shop.
There is a spare 50A (double pole) breaker that ends in a 220vac outlet in the garage attached to the house.
What I want to do is replace the 50A breaker with a higher rated breaker (60A? 100A?), run new cable (4ga? 6ga? its only about 40ft to the shop) add another feeder panel in the shop, and install 2 220vac outlets. One for a welder/table saw (50A) and one for an air compressor (30A)
My questions are: What size breaker should I run to the new feeder panel? Can I get away with the 60A breaker feeding 50A and 30A cicuits? I understand that I would not be able to run both welder and compressor at the same time at max amp.
Do I need to have a breaker at both ends of the new cable, I.E. 60A breaker in main panel, and another 60A breaker in the feeder panel, both isolating just the new cable.
post-488-12747641200944_thumb.jpg main panel in house.
post-488-12747641596083_thumb.jpg current feeder panel in shop
