Guest 2adz Posted January 10, 2002 Share Posted January 10, 2002 Who can give me details on how to replace the old gas door on a 280Z with a motorcycle gas cap like I have seen in Big Phil's pictures. I have factory replica fiberglass quarters and I want to eliminate the gas door and put in an "aircraft style" filler cap but would like to hear some tips on how to incorporate it into the existing filler neck. Quote Link to comment Share on other sites More sharing options...
Guest Willieboy240z Posted January 24, 2002 Share Posted January 24, 2002 keep looking at older posts in this forum. It's in there somewhere..... Quote Link to comment Share on other sites More sharing options...
blueovalz Posted January 24, 2002 Share Posted January 24, 2002 If you still have the gas cap, and it's OEM assembly (i.e just lacking a door only), then have you considered the "Bullitt" Mustang fuel door. It can be made to work with fiberglass. It has a very slight curve to it, uses 6 torx screws to hold it on, and is a brushed aluminum appearance. This will require the OEM cap to still be intact though. This one still has the protective film on it. Quote Link to comment Share on other sites More sharing options...
blueovalz Posted January 24, 2002 Share Posted January 24, 2002 try this then... http://cgi.ebay.com/ebaymotors/aw-cgi/eBayISAPI.dll?ViewItem&item=600838856 Quote Link to comment Share on other sites More sharing options...
Guest Big Phil Posted January 25, 2002 Share Posted January 25, 2002 I used a motorcycle gas cap off of a wreck Honda CBR street bike. I cut the mounting assembly off the gas tank and welded it on. The mounting assembly filler neck mates with a gas resistant hose that connect to the car's gas tank. It would be difficult to bond the assembly to fiberglass. Your best bet is to use a aftermarket assembly that includes the filler neck. Sparco makes a kit that includes everything you need the mount it to your fiberglass panel. Phil Sparco racing fuel cap assembly Quote Link to comment Share on other sites More sharing options...
Guest Big Phil Posted January 25, 2002 Share Posted January 25, 2002 OOPs, here is the page. Sparco motorcycle style fuel door Quote Link to comment Share on other sites More sharing options...
clint78z Posted January 25, 2002 Share Posted January 25, 2002 I like this one for the Miata, it allows you to have a cable for extra security and ease of use. Miata Accessories Quote Link to comment Share on other sites More sharing options...
Guest Willieboy240z Posted January 30, 2002 Share Posted January 30, 2002 I recently ordered the Miata model Clint describes. I'll give you a full report once I get it. Quote Link to comment Share on other sites More sharing options...
Guest 2adz Posted January 30, 2002 Share Posted January 30, 2002 Big Phil, thanks for your insight and tips. I have the cutout section of a motorcycle tank with filler assembly, I think I can weld it to the existing quarter and put the fiberglass quarter over the top making the filler cap slightly recessed. What I had a question with is that my filler hose coming from the tank is about 3" I.D. and the motorcycle filler hole is about 2" or less in diameter. Did you use a reducer or something? Quote Link to comment Share on other sites More sharing options...
BayAreaZT Posted January 30, 2002 Share Posted January 30, 2002 Do you know what size diameter the Bullit Mustang cap is? Quote Link to comment Share on other sites More sharing options...
Guest Big Phil Posted January 30, 2002 Share Posted January 30, 2002 2adz, I used a 3inch to 2 inch reducer from Pep Boys. Normally it is used to reduce exhaust pipe diameter. It cost 2 bucks. I would like to replace my fuel filler hose with a new aftermaket piece. Does anyone know where I can find a fuel resistant hose that 2 inch diameter? Phil Quote Link to comment Share on other sites More sharing options...
blueovalz Posted January 30, 2002 Share Posted January 30, 2002 The Bullitt door is 6.2" OD and 4.5" ID, and about .3" thick. It looks identical to the Miata one, except for the lack of a "thumb" recess with which to open the door with. Is the Miata one a cap, or just a door? Quote Link to comment Share on other sites More sharing options...
jeromio Posted January 30, 2002 Share Posted January 30, 2002 It definately looks like the Miata one is a door. So, the Bullit one is a door/cap? I guess that would help to justify the additional $50. It's a tough call because I like the idea of a remote/lockable setup. But the chrome might verge on the geech a bit. Quote Link to comment Share on other sites More sharing options...
blueovalz Posted January 31, 2002 Share Posted January 31, 2002 The Bullitt door is just that, a door only. It has a brushed finished, but is shiny chrome on the inside. You'll still need a gas cap and it's assembly under it to seal the system. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted January 31, 2002 Share Posted January 31, 2002 Try West Marine, BoatUS or Boater's World for the 2" fuel filler hose. BoatUS has 2" Type A2 fuel vent/fill hose for $13.99/ foot. Quote Link to comment Share on other sites More sharing options...
jeromio Posted January 31, 2002 Share Posted January 31, 2002 Oh yeah. I am highly interested in some details on that Miata filler. Looks good in the pictures - hopefully it looks and feels as good in person. I'm trying to figure out if I need to have the filler on the driver's side. If I use this Camaro tank that I have, I may need to flip it (to the standard FBody orientation) in order to gain some exhaust clearance. In which case, the filler will need to be on the driver's side and I'll need to patch the passenger hole (easy enough) and create a driver's hole. Using one of these caps would make that lots easier. It would actually be nice to have it on the driver's side - much more convenient. Plus, if I do flip the tank, it can sit farther forward whichis better. Quote Link to comment Share on other sites More sharing options...
Trevor Posted January 31, 2002 Share Posted January 31, 2002 I was thinking about re-locating the filler also, if you need a longer hose here is a fairly cheap source for (filler/1 1/2" dia. gasoline compatible)hose.... . It's in the JC Whitney catalog in the marine (boat) section. 3ft, 5 ft, 10 ft sections. Quote Link to comment Share on other sites More sharing options...
jeromio Posted February 1, 2002 Share Posted February 1, 2002 You might just be able to buy a long length of bike brake/derailer cable. Tough routing it though. Quote Link to comment Share on other sites More sharing options...
Guest V8wannabe Posted February 1, 2002 Share Posted February 1, 2002 what about going electronic to open the door...short cable (if necessary) and a coil like the ones on electric door locks or a smaller version of what is used for shaved door handles? Came up with that idea because I have both sitting inmy garage. Quote Link to comment Share on other sites More sharing options...
