ckolander Posted May 27, 2010 Share Posted May 27, 2010 (edited) So on my 79 s130, I've always had problems with the idle, fluctuated and died. Today I decided to start pulling vacuum lines to check for suction. The first one I pulled was to the Fuel Pressure Regulator and now the car runs better than it ever has. This leaves me guessing that the FPR is clogged somehow, but why would it run even better without the vacuum? I am very confused and would appreciate any wisdom you wish to share. PS if you tell me to search.....been there done that Thanks, Chuck Edited May 27, 2010 by ckolander Quote Link to comment Share on other sites More sharing options...
stravi757 Posted May 27, 2010 Share Posted May 27, 2010 So on my 79 s130, I've always had problems with the idle, fluctuated and died. Today I decided to start pulling vacuum lines to check for suction. The first one I pulled was to the Fuel Pressure Regulator and now the car runs better than it ever has. This leaves me guessing that the FPR is clogged somehow, but why would it run even better without the vacuum? I am very confused and would appreciate any wisdom you wish to share. PS if you tell me to search.....been there done that Thanks, Chuck SO maybe it was just bad, why dont you try putting a different one in? Quote Link to comment Share on other sites More sharing options...
roger.svoboda Posted May 27, 2010 Share Posted May 27, 2010 WITH NO/little vacuum the fpr raises the pressure on the fuel rail thinking that you are at full throttle. put a pressure gage on the system and find out what is happening cheaper than throwing parts at it using the wild a** guess method. Perhaps your problem is a simple fuel filter partly plugged. Quote Link to comment Share on other sites More sharing options...
ckolander Posted May 28, 2010 Author Share Posted May 28, 2010 Thanks Roger, a buddy and I actually talked about doing just that this weekend to find out exactly where the problem is. Quote Link to comment Share on other sites More sharing options...
ckolander Posted May 30, 2010 Author Share Posted May 30, 2010 Ok so I was doing some investigating today, it seems as though there are 2 fuel pressure regulators on my car. The normal one under the hood attached to the fuel rail, then what seems to be another one directly after the fuel pump. once again i am stumped Quote Link to comment Share on other sites More sharing options...
stravi757 Posted May 30, 2010 Share Posted May 30, 2010 Ok so I was doing some investigating today, it seems as though there are 2 fuel pressure regulators on my car. The normal one under the hood attached to the fuel rail, then what seems to be another one directly after the fuel pump. once again i am stumped tahts not an FPR, I believe its called the fuel damper. Quote Link to comment Share on other sites More sharing options...
roger.svoboda Posted May 30, 2010 Share Posted May 30, 2010 yeah the fuel damper has given people problems. forgot about that cause mine is long gone. Just remove you won't miss it. Quote Link to comment Share on other sites More sharing options...
blatanttripod Posted June 19, 2010 Share Posted June 19, 2010 http://www.classiczcars.com/forums/showthread.php?t=36651 got to this link it might help you alot ive had problems with my 82 280zxt and this took care of it. Quote Link to comment Share on other sites More sharing options...
blatanttripod Posted June 19, 2010 Share Posted June 19, 2010 (edited) this guy actually fixed it . so check this guys page out http://www.zdriver.com/forums/showthread.php?t=28820 Edited June 19, 2010 by blatanttripod Quote Link to comment Share on other sites More sharing options...
