L28 wont stay running or rev
awoz87
ok so i picked up an l28 to throw into the 240z i picked up. the blown engine that was in the car when i got it already had the electronic distributor conversion. i basically swapped everything over onto the l28 long block. after getting it together and having no luck with it firing at all i discovered the distributor shaft was in backwards. for a quicker fix rather than pulling the oil pump i just switched all the plug wires around. i also replaced the plugs. so now it will fire and if i give it 1/4 throttle it will stay running, i had to retard the timing all the way to do this as if i advanced it at all the engine would not run. any ideas? is swapping the plugs wires around like i did not gona work? do i just need to drop the oil pump?
Edited by awoz87
