Head light alternatives
I don't really like the big round stock bulbs because you can't buy HID lights for them. I read somewhere (VB I think) you can get plastic bulbs with open backs for lamp inserts like on the hondas. So I was thinking would it be better to get this set-up with a $500 HID kit, or should I try to make the headlights from a 2002 Mitsu Eclipse fit? Just look at those suckers, they'd fit, right? What do you body junkies think?
Nemeziz, Those light kits look sweet! But what is the diffrence between the regular and the 'Tri Bar' style? And is that price for each? Sounds pretty good.
Hey also, I heard a while back you could run a straight wire from the alternator (14 volt output) to the pos. side of your lights and it will brighten them, since they use the switch on the neg. side of the bulb they will still work like normal. Is this right, like I said it was a while ago so I forgot what to do.
Thankx, Nic
