280zx steering shaft/box clearence
I'm looking to build a budget 4.3 turbo powered 280zxT. After speaking with a memeber john scott i decided to look into this more. Only problem is that he has a 240z and im looking to do a 280zx. Is there anyone on the forums that has a 4.3 swapped in their zx? I wanted to see some pics to use as a reference? also whats all i hear about this steering issue with the zx steering shaft/box or what ever, that causes it to be left out of the swap kit world? heard there was some clearence issue? Technically if you can swap in a lt1, an retain stock exhaust manifolds the you should be beble to use the 4.3 stock manifolds as well.
