280zbeeT Posted July 18, 2010 Share Posted July 18, 2010 anyone here who could or knows anyone who could help a brother out with a good longevity and power tune for my 280z gone l28et high comp. engine? lots an lots of mods, but worried about detonation.. I can pay, but I am in between jobs.. obviously I will pay, but if possibly could work somthing out or a deal that would be just so amazing. Please let me know. 760 802 9591, leave a msg for me, or email kink15@hotmail.com or just PM me, I check hybridz like 20times a day. thank you guys! Quote Link to comment Share on other sites More sharing options...
280zbeeT Posted July 18, 2010 Author Share Posted July 18, 2010 Engine Upgrades: 76 280z w/ 82 280zx p90head with NA Cam 75 280z n42 short block .30 bore ARP Rod Bolts ARP Head Studs 76 Intake with 60mm Throttle Body Rx7 550 Injectors Rx7 Oil Cooler 24x12x3 Intercooler 2.5" Intercooler Piping HKS Blow-off Valve Haltech E11-V2 With flying lead harness Palnet Fuel Rail with Fuel Gauge Tial Wastegate w/17 PSI Spring. GT30R Ball Bearing Turbo DynoMax 2.5 Welded Exhaust Dual Electronic Fan from Summit 82 Maxima Alternator Zeitronics Wideband with EGT sensor Walbro Fuel Pump K&N Air Filter Stainless Steel Lines CenterForce Clutch HKS Turbo Timer Boost Controller ((*trying to decide between msd6a an lsx coils*)) so that would be involved! Drive Train: 240SX 5 Speed Transmission B&M Shift Kit (Sport Short Shifter) 3.9 Rear End Spicer U Joints in Driveshaft and Half Shafts Brakes: Toyota S13 Calipers in Front Drilled Rotors Stainless Steel Brake Lines ZX Brake Booster Suspension: Tokico Illuminas 5 Way Adjustable Shocks Tokico Reds 5 Way Adjustable Springs Poly-Bushings all the way around MSA-Sway Bars Quote Link to comment Share on other sites More sharing options...
jakeoster Posted July 18, 2010 Share Posted July 18, 2010 Question unrelated: How do you deal with smog? Noticed you were from San Diego, as is I. Quote Link to comment Share on other sites More sharing options...
280zbeeT Posted July 21, 2010 Author Share Posted July 21, 2010 my car is smog exempt. the dmv changedf it to a 75, but its a 76.. build in 75 tho. Quote Link to comment Share on other sites More sharing options...
