janaka Posted July 21, 2010 Share Posted July 21, 2010 Hey guys I'm currently looking a a magnacharger MP112 that was for the 4.8/5.3/6.0L LS motors. I'm currently running an LS1 from the firebird with only a water pump and alternator (no ps/ac). I know that it will bolt up to the heads but I'm wondering about the belt for the accessories (and now blower). Does anyone know if they are the same? Obviously I'll need a longer belt but otherwise will they line up? The current owner of the kit says that it was installed on an LS2 vette and says it'll bolt onto the LS1, i just want to make sure I know what i'm getting into compatibility wise. thanks Quote Link to comment Share on other sites More sharing options...
Savage42 Posted July 21, 2010 Share Posted July 21, 2010 The truck accessories sit a bit farther forward and the Corvette setup is definitely different than the Camaro accessories. Not sure if truck & Vette are the same, but sure that they are different than Camaro. Quote Link to comment Share on other sites More sharing options...
Cable Posted July 21, 2010 Share Posted July 21, 2010 If it was intended for a truck, then you will have to run the truck accessory drive unless you swap out the front nose/shaft on the supercharger to line up with your F-Body accessories. Hope that helps. Quote Link to comment Share on other sites More sharing options...
janaka Posted July 22, 2010 Author Share Posted July 22, 2010 that would mean swapping water pump, alt and crank pulley? poopstick. Quote Link to comment Share on other sites More sharing options...
SUNNY Z Posted July 24, 2010 Share Posted July 24, 2010 so, about $100, worst case scenario. That's what i paid for those three items in the ls1 f-car variety, which are slightly harder to get a hold of. Quote Link to comment Share on other sites More sharing options...
Cable Posted July 28, 2010 Share Posted July 28, 2010 How much did you pay the MP112? Quote Link to comment Share on other sites More sharing options...
janaka Posted August 9, 2010 Author Share Posted August 9, 2010 I didn't buy the blower in the end. Just too many things weren't making sense from the seller; he had it insalled on an LS2 and said it bolted on fine, then when I asked about the accessories he said he changed them for the truck ones but "forgot" to mention that... He was asking about $2300cdn obo + shipping. Quote Link to comment Share on other sites More sharing options...
Dans toy Posted September 3, 2010 Share Posted September 3, 2010 first time commenting. I have a 74 260 with an LQ4/magnacharger going in. It's working, but a tight fit. Mine has the truck excessories that stick out further. Good luck with projects Quote Link to comment Share on other sites More sharing options...
Dans toy Posted September 3, 2010 Share Posted September 3, 2010 first time commenting. I have a 74 260 with an LQ4/magnacharger going in. It's working, but a tight fit. Mine has the truck excessories that stick out further. Good luck with projects I had this blower setup in me 03 silverado. The power curve was great. Even for a truck. 12.78@109mph ,2.03 60ft.street tire/ 12.48@112mph,2.07 60ft. street tires,shot of nitris. Quote Link to comment Share on other sites More sharing options...
