staledale Posted May 5, 2002 Share Posted May 5, 2002 When patching a rust hole, I've always just flush fit the patch and welded it. But I'm replacing a panel that raps around another panel and then it's spot welded. What do you do to protect the bare metal between the two panels? I'm afraid of any paint,primer between the two causing the weld to be bad. Any ideas out there? thanks Quote Link to comment Share on other sites More sharing options...
denny411 Posted May 5, 2002 Share Posted May 5, 2002 Its about 22 bucks a can, but you should use weld through primer. It comes in a spray can and can be bought at most auto body supply stores. After use be sure to turn the can upside down and spray to clear the tip and nozzle or you will have a very expensive paper weight Quote Link to comment Share on other sites More sharing options...
MikeS Posted May 5, 2002 Share Posted May 5, 2002 I have had good luck with spray on cold galvanizing compound. It's 5 to 7 bucks a can, color is lite flat gray. this can also be used as a weld thru primer. Quote Link to comment Share on other sites More sharing options...
staledale Posted May 5, 2002 Author Share Posted May 5, 2002 The lower rear quarter, that raps around the inter wheelhouse. Also on a mustang I pull the seat risers off the floor and cleaned it up. I used a spot weld cutter and plan to put it back down and reweld where I cut the spots. Thanks guys Quote Link to comment Share on other sites More sharing options...
staledale Posted May 7, 2002 Author Share Posted May 7, 2002 yes it does, thanks Quote Link to comment Share on other sites More sharing options...
