Delasangre4231 Posted July 28, 2010 Share Posted July 28, 2010 Ok this is just pissing me off now. The car died a while back and I thought there was a short but I replaced the battery and all was well. Now the battery stopped holding a charge again so what is ruining my batteries? (third battery I have been through, drives one day and the next the battery won't hold a charge, put a new battery in it and the car fires right up) What is destroying batteries? Quote Link to comment Share on other sites More sharing options...
-eric Posted July 28, 2010 Share Posted July 28, 2010 Voltage regulator? Maybe get the alternator checked, couple things you could try. Quote Link to comment Share on other sites More sharing options...
Delasangre4231 Posted July 28, 2010 Author Share Posted July 28, 2010 So take the alternator to get tested? Quote Link to comment Share on other sites More sharing options...
-eric Posted July 28, 2010 Share Posted July 28, 2010 I would, but I just re read, it says it stops holding a charge, normally a bad altenator just doesnt charge the battery and leaves it dead. Do you mean the battery wont charge by itself out of the car, or just doesnt recharge in the car. Check the charging voltage while its running. Or try a paracitic drain test. Quote Link to comment Share on other sites More sharing options...
Delasangre4231 Posted July 28, 2010 Author Share Posted July 28, 2010 Before when it was running it was at 14-16 volts at the battery terminals while running, but now when I hook up jumper cables it has normal power but the second I take of the jumper cable it has no power... Quote Link to comment Share on other sites More sharing options...
Trbulnt Posted July 29, 2010 Share Posted July 29, 2010 Are your battery cables making good contact with the battery? If you can wiggle the cables while they are attached to the battery than that is your problem. May sound dumb but this may be your problem. Quote Link to comment Share on other sites More sharing options...
akumazedex Posted July 29, 2010 Share Posted July 29, 2010 Sounds like a parasitic draw.. Check for it with a meeter hooked up in series with the battery.. (disconnect a battery cable and put the meter at the battery to the disconected cable with the car off) helps if you got a charged battery too. Anything over about 0.5v is high. If it is, start pulling fuses one by one to pinpoint the circuit that's drawing the power. Quote Link to comment Share on other sites More sharing options...
akumazedex Posted July 29, 2010 Share Posted July 29, 2010 *edit* 0.05 amps is an acceptable draw on the battery. Not volts. Quote Link to comment Share on other sites More sharing options...
Augustus Posted June 24, 2011 Share Posted June 24, 2011 On 7/28/2010 at 3:50 AM, Delasangre4231 said: Ok this is just pissing me off now. The car died a while back and I thought there was a short but I replaced the battery and all was well. Now the battery stopped holding a charge again so what is ruining my batteries? (third battery I have been through, drives one day and the next the battery won't hold a charge, put a new battery in it and the car fires right up) What is destroying batteries? Start the car, disconnect the battery and if it shuts off you got a bad alternator. Quote Link to comment Share on other sites More sharing options...
Delasangre4231 Posted June 24, 2011 Author Share Posted June 24, 2011 Ya... I kinda don't have a z anymore. But next year I will me in the market for a nice 240z! Quote Link to comment Share on other sites More sharing options...
