N/A to turbo oil pan conversion question
Is it crucial where the fitting on the oil pan for the return line goes? I just gonna tap a hole and put a fitting on an na pan for the turbo oil return. Just wanna know if there's a specific spot it has to be or do I got some room to play with? I know it goes on the left side of the pan roughly in the middle.
  On 7/30/2010 at 9:08 PM, battlesquaddatsun said:
I read up on that allready, but it shouldn't matter if it's off a little right? I'm getting some eBay oil lines anyways so I'm not to concerned if I have to modify them a bit.
Did you? :lol:
  On 9/3/2009 at 1:14 AM, FlatBlack said:
Worth mentioning: I ended up cutting the 90* off of the outlet pipe and using a longer soft line [no kinks] because my flange that I welded on was a bit long. If your home-made pan doesn’t line up perfectly you can make it work.
Edited by FlatBlack
  • 3 weeks later...
