Balance-Tubed vs Non Balanced-Tube Triples Manifolds
DAW
I have both a balanced-tube manifold (Cannon) and a non balanced-tube manifold (Lynx) that I can use and wonder what the experience is with the two types... I can postulate; but I'd like to hear from someone who has actually compared the two types and what they found re tuneability, performance/driveability, etc? I think this is a different topic from tuning triple carbs, per se, so I posted it as a separate topic...
DAW
OK, I understand that synchronization is clearly more accurate with individual (non-balanced) runners, and that power band would be less peaky and driveability better with balanced triples...what I'm questioning is the optimal way to balance the carbs...
does runner-grouping matter?
do it, dyno it, and post the results, then there will be no conjecture or supposition...
I could group my Mikuini Manifold through the ports and using tubing. I doubt any measurable difference will result.
