Moltar Posted August 11, 2010 Share Posted August 11, 2010 I have an interesting Holley 390 cfm carburetor. This carburetor was designed for small engines in mind (the old Pinto/Vega 4 cylinder motors for example). It utilizes a reverse power valve which also pretty unique. Here is a link to all the info on the 6299 (I figured direct reference is better than me loosely quoting him). Holley 6299 History Carb was brand new when I bought it 8 months ago, and it has maybe 20 miles on it. I replaced both float needles, accelerator pump diaphram, as well as the power valve (#6). Both the float bowl gaskets as well as the metering block gaskets have been replaced with the Holley blue non-stick type gaskets. Comes with a box of jets (sizes: 43, 44, 45, 47, 49, 50, 51, 52, 53), power valve block off plate, and a partially used rebuild kit (I used the rebuild kit to get the carburetor back up to spec after sitting for a few months). What it needs is a reverse power valve from a 6299 rebuild kit, which can be found here. I have a normal power valve in there right now, and I don't know how well it will work (you can always use the supplied power valve block off plate). Asking $175 shipped, or $140 local. Both are OBO. ~Thanks Quote Link to comment Share on other sites More sharing options...
blakerflynn@gmail.com Posted August 11, 2019 Share Posted August 11, 2019 On 8/11/2010 at 11:04 AM, Moltar said: I have an interesting Holley 390 cfm carburetor. This carburetor was designed for small engines in mind (the old Pinto/Vega 4 cylinder motors for example). It utilizes a reverse power valve which also pretty unique. Here is a link to all the info on the 6299 (I figured direct reference is better than me loosely quoting him). Holley 6299 History Carb was brand new when I bought it 8 months ago, and it has maybe 20 miles on it. I replaced both float needles, accelerator pump diaphram, as well as the power valve (#6). Both the float bowl gaskets as well as the metering block gaskets have been replaced with the Holley blue non-stick type gaskets. Comes with a box of jets (sizes: 43, 44, 45, 47, 49, 50, 51, 52, 53), power valve block off plate, and a partially used rebuild kit (I used the rebuild kit to get the carburetor back up to spec after sitting for a few months). What it needs is a reverse power valve from a 6299 rebuild kit, which can be found here. I have a normal power valve in there right now, and I don't know how well it will work (you can always use the supplied power valve block off plate). Asking $175 shipped, or $140 local. Both are OBO. ~Thanks I'd like to buy this if still available text me at 734-748-1609 Quote Link to comment Share on other sites More sharing options...
pledgekincaid Posted August 11, 2019 Share Posted August 11, 2019 Baker, hate to break it to you but this is a 9 year old post. Moltar hasn’t logged on since 2015.... Quote Link to comment Share on other sites More sharing options...
