randy 77zt Posted August 16, 2010 Share Posted August 16, 2010 any recommendations?i have a 10 year old autometer in the clock spave in my 77.having a passenger watching my laptop and reading the vipec ecm data shows the boost gauge to be very far behind in what my engine is really doing.my idea would be a fully electronic gauge using a map sensor.the outputs on the vipec do not support a boost gauge.anybody know of anything that would work? Quote Link to comment Share on other sites More sharing options...
510six Posted August 17, 2010 Share Posted August 17, 2010 http://www.aemelectronics.com/tru-boost-boost-controller-gauge-757 I have seen one of these work very well on an turbo Honda. http://propartsllc.com/spekGaugeController.php?subCatID=20 Quote Link to comment Share on other sites More sharing options...
jmabo205 Posted September 1, 2010 Share Posted September 1, 2010 i personally like mechanical boost gauges for the sole reason its mechanical. You get better and more accurate readings from the vacuum and you don't have to worry about if its connected right. Its reliable and cheaper than a digital one. just my 2 cents Quote Link to comment Share on other sites More sharing options...
ktm Posted September 2, 2010 Share Posted September 2, 2010 On 9/1/2010 at 1:19 AM, jmabo205 said: i personally like mechanical boost gauges for the sole reason its mechanical. You get better and more accurate readings from the vacuum and you don't have to worry about if its connected right. Its reliable and cheaper than a digital one. just my 2 cents Says who? You can get very accurate readings with an electric (either digital or analog) gauge. It is simply a MAP sensor hooked up to a vacuum source that is connected to the manifold. The MAP sensor connects to the gauge with a harness that has two plugs, one for the gauge and one for the sensor. There is nothing to screw up. You need a ground, ignition hot and dash light source. That's it. Quote Link to comment Share on other sites More sharing options...
Calgary280ZT Posted September 3, 2010 Share Posted September 3, 2010 Bo, what about the boost readings from your Wolf V500? My mechanical gauges says 10 psi when my Wolf dash display says 5.4-6 psi. (sorry for the thread hijack) On 9/2/2010 at 10:54 PM, ktm said: Says who? You can get very accurate readings with an electric (either digital or analog) gauge. It is simply a MAP sensor hooked up to a vacuum source that is connected to the manifold. The MAP sensor connects to the gauge with a harness that has two plugs, one for the gauge and one for the sensor. There is nothing to screw up. You need a ground, ignition hot and dash light source. That's it. Quote Link to comment Share on other sites More sharing options...
ktm Posted September 3, 2010 Share Posted September 3, 2010 Are you sure your mechanical gauge is accurate? What does your LMA-3 auxbox say? Quote Link to comment Share on other sites More sharing options...
Calgary280ZT Posted September 4, 2010 Share Posted September 4, 2010 LOL...my LMA-3 auxbox hasn't worked for 2 years. During the painting the wires were pulled out of the front. Before that, it stopped reading AFRs. Wiring into the box is the same. I plan to test and re-calibrate the wideband 02 sensor next week. But those wires on the front of the box...a mystery.... On 9/3/2010 at 11:33 PM, ktm said: Are you sure your mechanical gauge is accurate? What does your LMA-3 auxbox say? Quote Link to comment Share on other sites More sharing options...
ktm Posted September 4, 2010 Share Posted September 4, 2010 Mark, the LMA-3 should work. It could be something as simple as the dummy plug that is necessary for the LC-1 cable is missing. I wish I could look at the setup myself. Quote Link to comment Share on other sites More sharing options...
softopz Posted September 4, 2010 Share Posted September 4, 2010 I think both mechanicals and electrical have there days Try getting a cheapo mechanical boost gauge and see what it says comparing between the two. Even better is hdi boost gauge. moth mechanical and digital read out. If you have their boost controllers they need no wiring it plugs right in there. I have the EBC and was thinking of getting this gauge but opted against it How do you like the Vipec system? Quote Link to comment Share on other sites More sharing options...
