30 ounce Posted August 20, 2010 Share Posted August 20, 2010 I installed an MSA 6AL and the MSD 8920 tach adapter and I still have no tach function. The tach does move a little bit when I rev the motor. Does anyone know how to hook this up so my tach works? Quote Link to comment Share on other sites More sharing options...
sweetleaf Posted August 21, 2010 Share Posted August 21, 2010 Witch year car and distributor? Quote Link to comment Share on other sites More sharing options...
30 ounce Posted August 21, 2010 Author Share Posted August 21, 2010 Late 260 with stock 260 distributor. I hooked up the MSD to the magnetic pickup in the distributor and the MSD 6AL seems to work fine. I ordered the 8920 adaptor and hooked it up per the instructions but I'm not sure wich wires drive the tack. I have a black with green stripe and a black with blue stripe and a solid blue that were all connected to the original ballast resistor wich has now been removed. I connected the purple wire (tack drive) from the MSD 8920 to the solid blue wire and the tack just barely moves off 0 when I rev the engine. Quote Link to comment Share on other sites More sharing options...
Bahraini240z Posted August 21, 2010 Share Posted August 21, 2010 Subscribed Quote Link to comment Share on other sites More sharing options...
30 ounce Posted August 21, 2010 Author Share Posted August 21, 2010 Sorry...what does subscribed mean? Quote Link to comment Share on other sites More sharing options...
Bahraini240z Posted August 21, 2010 Share Posted August 21, 2010 This is a way so I can follow up the discussion on this thread via email notifications. It is a matter of interest to me Quote Link to comment Share on other sites More sharing options...
30 ounce Posted August 21, 2010 Author Share Posted August 21, 2010 Oh, thanks for the explaination. Beautiful Z by the way!! Quote Link to comment Share on other sites More sharing options...
MikeyZee Posted August 21, 2010 Share Posted August 21, 2010 Here is a post that helped me. http://forums.hybridz.org/index.php/topic/37376-getting-your-early-240z-tachometer-working-with-an-msd-6-series-ignition/page__p__298874__hl__%2B8920+%2Bmsd__fromsearch__1#entry298874 It is real straight forward. Hey your in Colorado too? I'm in Parker. Quote Link to comment Share on other sites More sharing options...
30 ounce Posted August 21, 2010 Author Share Posted August 21, 2010 Hi MikeyZee! I saw that post but the wire colors don't make any sense as my colors are completey different. I have a black wire with green stripe a solid blue wire and black with blue stripe. I was in Parker last weekend with my Z!! Would love some help if you got time!! Quote Link to comment Share on other sites More sharing options...
Bahraini240z Posted August 21, 2010 Share Posted August 21, 2010 On 8/21/2010 at 2:31 PM, 30 ounce said: Oh, thanks for the explaination. Beautiful Z by the way!! Thanks Quote Link to comment Share on other sites More sharing options...
MikeyZee Posted August 21, 2010 Share Posted August 21, 2010 (edited) Is your 260 an EFI or carb? If it's EFI here is a link on a previous post http://forums.hybridz.org/index.php/topic/17205-msd-6btm/page__p__125166__hl__%2Bmsd6a+%2B8920__fromsearch__1#entry125166 Check out the link in there with the hand written diagram. Also if you need the FSM it is available here. http://www.xenons30.com/reference.html They have all the factory wiring diagrams. Not sure about the 260 but on my son's 240z which has a different tach it was a little different. Edited August 21, 2010 by MikeyZee Quote Link to comment Share on other sites More sharing options...
30 ounce Posted August 30, 2010 Author Share Posted August 30, 2010 I figured it out!! Unplugged the stock transistor ignition unit and the tach works. Quote Link to comment Share on other sites More sharing options...
30 ounce Posted September 2, 2010 Author Share Posted September 2, 2010 Well...I thought I had this fixed. The tach works but sometimes goes crazy. Sometimes when I rev to 3000 rpm's the tack goes all over the place. Strangely, if I turn the parking or headlights on it will work flawlessly!! Do I need to put a risistor in line? Quote Link to comment Share on other sites More sharing options...
vantage Posted September 6, 2010 Share Posted September 6, 2010 When you say all over the place, does the needle bounces up to a higher RPM than the actual one, or does it bounce between zero and the actual RPM? If it bounces between zero and the current RPM, then the tach signal is too weak, if it bounces all over the place there is something wrong with the duty cycle of the trigger signal (unlikely in your setup) or the signal is too strong and confuses the input stage of the tach. This should not happen with a tach adapter, though. Turning on the parking lights does not change the cars voltage so much that it would have an effect, this sounds rather like a wiring problem or issue with the alternator/regulator. Could you measure the cars main voltage while idling and also when the tach stops functioning? Quote Link to comment Share on other sites More sharing options...
30 ounce Posted September 23, 2010 Author Share Posted September 23, 2010 It actually bounces from 0-8000 rpm's. I suspected it had something to do with the charging circuit. My ammeter guage seams to randomly charge or discharge and it seammed to act up when it was slightly to the positive. mM battery doesn't always get fully charged. Guess it's time to upgrade the alternator and get rid of that external regulator. Quote Link to comment Share on other sites More sharing options...
