Rat Z Panel
duragg
  • 1 month later...
Ok, sorry for the delay.
I had to reconfigure the tail light logic and have all the lights wired along with ignition.
On a boondoggle over the weekend I mooched a ton of cool switches from an aircraft parts depot.
Will get back to work on this shortly this week.
Good progress today.
Installed a Master Relay and Master Switch.
What you see in this picture is the Master switch on top.
Below that are 3 switches.
Center is Running Lights On.
Left is low beams, right is high beams.
Bought a new batter and new headlights.
Got a rough cut of the .050" Aluminum panel cut and fit.
Its rough. Kills me. I want to WaterJet a panel from .125" aluminum.
But its a RatZ... But its a RatZ... But its a RatZ.
Tony the sheetmetal magician at Superfinishers said he'd straighten it up once I get it all hacked up good.
Tired. Thirsty. Done for the night.
Tomorrow is Cruise on Central in Phoenix... Got to get the Benz ready cuz the Z won't be.
Way to go man that looks really good. A little big and bulky for my taste. This is your car tho brother so U rock it the way you want. I also have stripped my interior and wireing harness along with AC stuff for weight but im dropping in a 350 and moving the battery to the rear for 50/50 weight. My buddy has been tryin to talk me into an aluminum dash . Again GOOD JOB.
I agree it could be trimmed down a bit more. Actually the cell phone image doesn't show the correct proportion.
Probably going to do it over again once I figure out where I want all the switches and stuff.
Next one would be .090" Al cut on a Waterjet.
But this will work for now as mockup.
Tj
Figuring out the headlights and taillights was a chore.
Recommend you completely abandon the stock scheme and just do your own thing.
I made the turnsignals dedicated front and rear.
Brake lights are the two top reds.
I used a dedicated (3rd brake light) wire to run the brake lights
Running lights are the smaller outboard red.
Headlight circuitry using toggle switches is strange.
I had to run the Hi-beam power through a low-beam switch and so on.
It was just trial and error till I got everything to do what I wanted.
I had to use DPDT switches in many places to get the indicator lamps working correctly and not feedback into other circuits (Hazard, High Beams, and T/S).
Totally trial and error process. I like switches so it looks like a battleship in there.
Yea I figured that it was going to be a trial and error process because I will also have switches running everything. I DO NOT want my turning signals as switches tho. I am going to get a universal turning switch for the steering column but other that that everything will be on toggle. I should go through the trouble of resizing some pics for you guys to see.
I liked the idea of a "HOTAS" panel like that used in fighter aircraft.
The left hand is always on the wheel and has no other jobs.
The right hand manages the stick and switches since it has spare time.
I'm just trying to be different.
This panel is a "dash one" proof of concept mockup, so go easy on me..
All the electronics work, might change some switches and positions, but for now:
Top guarded switch is hazards
Down low from left to right
1) Master Switch
2) Instruments (and backup lights I think)
3) Fuel pump (Down Prime - Off - Up On)
4) Ignition (Up-Engine Run / Down-Engine Stop)
5) Red guard Start
Below that
Center - Running lights and Enable
Left Low beams
Right is high beams.
Down by the shifter out of view is turn signals and reverse lights.
Gonna make a real panel from water-jet .090" aluminum once the mockup is done.
L24 with Triple Webers is fun to drive, but pretty slow.
Maybe I will swap in an L28 for a while and keep my eyes out for an LSx motor.
Got to get the car running again and back on the road.
Then I need to think about real brakes and an LSD.
Until I have real brakes and the LSD it doesn't seem smart to put in any big HP.
Got a little work to do yet...
280zx engine and brakes work well in a 240-280. ZX struts are the best platform because they will adapt almost any larger brake kit out there. 80 dollars from the wrecking yard, and walaahhh.
Hey, another question.
I am deleting the heater core altogether.
Do I just cap off the old lines?
Or do I need to run them together?
Tj
You could do either. I have, in the past, capped off the lines at the block. It saves space and it looks better too. If you aren't using the heater, there is no need for the hoses either.
OK, while you are here...
My brother had the car last and said there was "No Spark".
I have rewired everything now and still no spark.
Coil is Smoking Hot after having power for a few minutes.
Crane XR700 with a coil and the optical pickup in the Dizzy.
I think...
+12V goes from battery (panel switch) to the + side of the coil.
Wire from the - side of the coil goes back to the panel for the tach.
+12volts leaves the + side of the coil and powers the Crane XR700 I think.
Ehh. Need to pull the Crane manual and check this all out.
