hagerty_justin Posted August 28, 2010 Share Posted August 28, 2010 Hey, I have been looking around about why my headlights only have lowbeams, I asked the guy at my local auto parts store and he said that there is a relay called the passing relay so I did some searching and found one on black dragon. I cant find anything about where the relay goes. I attached pictures of the relay and hopefully someone can tell me where it goes, or if I got took for 15 dollars Thank you for all your help! Quote Link to comment Share on other sites More sharing options...
24OZ Posted August 28, 2010 Share Posted August 28, 2010 I have a similar issue, oly my low beams work. I've been told it's a bad earth. I've looked at the wiring diagram and by the look of it I need to check the earth at the combi switch, could be bad contacts there. You may want to give that a try. Quote Link to comment Share on other sites More sharing options...
NewZed Posted August 28, 2010 Share Posted August 28, 2010 Z cars that have sat for a while tend to have the low beam/high beam switch get gummed up. It's in the turn signal lever attachment. Have you tried pulling back on the turn signal lever? It is a toggle switch for high beam to low beam. If the turn signal toggle doesn't switch the lights from high to low, you can try cleaning the switch. I have had success with Deoxit contact cleaner, just spraying it in to the switch itself then working the toggle back and forth. What year and model car are you talking about and how long have you had the problem? No idea what that part is that you're showing. Quote Link to comment Share on other sites More sharing options...
ktm Posted August 28, 2010 Share Posted August 28, 2010 (edited) My low beam/high beam switch needed to be shimmed (don't know why) in order to get the high beam to engage. You should hear a definite click when turn on the high beams. If your lower beams work, then the ground works as the high beams and low beams share the same ground on a 240z. The ground is located on the turn signal stalk. The combo switch only provides power to the lights and the parking lights, the low beam/high beam switch is where the ground it located. Edited August 28, 2010 by ktm Quote Link to comment Share on other sites More sharing options...
hagerty_justin Posted August 28, 2010 Author Share Posted August 28, 2010 (edited) http://www.blackdragonauto.com/icatalog/zr/full.aspx?Page=58 This is where i got the part, its near the bottom and is for headlight relays Z cars that have sat for a while tend to have the low beam/high beam switch get gummed up. It's in the turn signal lever attachment. Have you tried pulling back on the turn signal lever? It is a toggle switch for high beam to low beam. If the turn signal toggle doesn't switch the lights from high to low, you can try cleaning the switch. I have had success with Deoxit contact cleaner, just spraying it in to the switch itself then working the toggle back and forth. What year and model car are you talking about and how long have you had the problem? No idea what that part is that you're showing. Okay I will take a look at that My car is a 74 260z and I would love to fix the highbeams because the lows are so terrible I cant drive over 30mph at night Edited August 28, 2010 by hagerty_justin Quote Link to comment Share on other sites More sharing options...
